Question about Hisense TL-3220 Television
Sound stopped and comes on and off intermittingly
Hisense model tl3220 working fine and then the sound went off. Finally came back on but then went off again. Picture and everything else is fine.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem could be any of several possibilities:
  • speakers cutting out (most unlikely for 2 spkrs to go out at the same time);
  • the built-in amplifier (likely) but once off should not be coming back if faulty; if so then possibly only a cold solder;
  • sound processing (possibly, but would require extensive checking, testing and voltage measurements);
  • tuner (possibly if all channels exhibits same no sound problem);
  • cable provider, in some instances, the signal from the cable provider does not match the input requirement of the Hisense TH3220.
This of course would require opening the unit, perform voltage measurements,determine faulty component and subsequent part(s) replacement. Further, a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron would be required. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings.Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 18, 2008
  • 1,512 Answers
Hi
Sounds like there is an intermittent electronic fault in the sound section of your set. If it is still under warranty, then I would suggest contacting the people you purchased it from to arrange for it to be replaced or serviced. Is about the only thing you can do. If it is outside warranty, try contacting Hisense and express you disappointment,. they may just fix it for free. Other than that, you could hook a home theater system up to it and check to see if the audio is there at a line signal level and use that to solve the problem :)
regards
robotek
  • Graeme Ross
    Graeme Ross Dec 18, 2008
    if none of these suggestions work, then you will be faced with getting a repair guy out to have a look for you. Use an Authorised agent for Hisense. They tend to have better knowledge of the issues that may be affecting the set. If you are in Asutralia they have a 3 year warranty. Check here for details.
    Genius:
  • 1,199 Answers
This sounds like a problem in the volume control unit! switch may need replaced!
    Scholar:
  • 86 Answers
Sounds like a loose connection somewhere.
  • Sudo Bash Dec 18, 2008
    or a short maybe...
I have a Hisense 55K20DG 2013 MODEL and recently the picture went black/white and very dim with the sound still intact. After a few days the picture went out completely with no logo.still have sound
Throw it away. Seriously most of the parts will wind up costing more than a replacement set...and you are taking a chance that they will even fix it. Hisense has a poor reputation for customer service and does not make service info readily available. If you do decide to try and repair it....yu probably need at minimum an led driver board...assuming the led is not bad.
Aug 28, 2016 | Hisense Televison & Video
I have a hisense LCD tv model # LTDN42V68US and It won't come on the screen went black. No sound, no visual either, when u turn the power on the shuts back off after a minute or two. Screen flickerd
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 14, 2015 | Hisense Televison & Video
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
I have a LCD32W60D Hisense Television. The AV channel is now flashing 'no signal' so cannot get my dstv channels anymore - it has been fine for the last year. When I switched on today it was fine but...
Try the flashlight screen test with TV on to be sure an image is showing, hold flashlight above at an angle, if you see a faint image the motherboard needs replacing
Oct 30, 2017 | Hisense Televison & Video
When I turn on my LCD TL3220 the screen shows a 3" x 6" silver box that says "no sync detected". I have checked the cable box and that seems to be working. Any suggestions
The word ''no sync detected' means that there is no video connection between the cable box and the TV set. Isolate the source of trouble by connecting to the TV a prevoius video source that worked properly e.g DVD player. You should also try to get a new set of video cables as the ones you have may be internally broken.
Please follow the installation instructions carefully especially the colour codes of the video and audio cables i.e yellow cable to yellow connectors of TV and cable box , Red cable to red connectors of TV and cable box etc.
good luck!
Oct 09, 2010 | Hisense TL-3220 Television
93 accord lx problem
Sounds like your valve seals are gone. Expensive, unless you can do it yourself.
May 20, 2009 | 1992 Honda Accord
Power steering fails
I had the same problem, there is a cooling fan for the power steering pump that went out and caused some damage to the pump. The intermitent problem finally got worse and I had the pump replaced read: expensive about $1000. See if they have a rebuilt pump available.
Apr 14, 2009 | 2003 Mini Cooper
Hisense 42inch lcd tv
It sounds like it's the inverter panel which lites the lcd back light.
If it's under warranty, try to replace it, or take it in for svc.
Dec 23, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
