I replaced my Janitrol 7 wire thermostat with an RTH7500 which now controls my heatpump system. The switches on the Janitrol were cool - off - heat - Em Heat. Does that mean I have auxiliary heat? There is no other heating system besides my heat pump. Should the 0170 function on the new thermostat be set at #2 or #7?
  • tom1976 Dec 19, 2008
    does "tat" really mean "that"? You should know what function 0170 stands for, it't your product for God's sake. This is extremely slipshod, sloppy work on your part. I am not impressed at all. I wlll delete the explatives.
    Thanks pal
  • 334 Answers
There should be electric heat strips in the airhandler.
They automatically come on when the unit goes into defrost, the thermostat is turned up more than 7 degrees over the indoor temp or if the outdoor temp is just so cold the HP cannot keep up.
Tat is your auxillary or emergency heat.
What does the new t-stats installers booklet say that the 0170 function and #2 #7 options are for?
If it is for gas vs elec heat then set it on the elec option.
The difference is that in gas heat systems the blower comes on a few min AFTER the furnace fires up to allow the heat exchanger to get hot.
In an electric furnace the blower has to come on emediatly because the heat strips get hot emediatly and if the blower is delayed the system will shut of in high temp overload.
Posted on Dec 18, 2008
  • Danny Clark
    Danny Clark Dec 19, 2008
    No ignorant, its not my "product".
    You are not talking to the manufacturer of the unit here.
    I am a heating and air conditioning technician. I service and repair all brands of units.
    If I carried manuals, diagrams and parts for every unit I service I would need to have a Mac truck 18wheeler following me around.
    Oh my, I forgot an "H", the sky is falling chicken little. I'm sure that one widdle spelling error made the whole post illegible.
    However, it IS YOUR unit. If anyone has the code list it should be you.
    But no, someone is kind enough to "for free" answer your questions, explain how the system works, and ask more questions to clarify, and what do you do?
    You Climb up on a false high horse of ignorant arrogance and hurl insults.
    Then you have the nerve to rate it inappropriate?
    You asked TWO questions. I answered the first. I asked clarification on the second, explained how the system works and then answered the second according to what little information you provided.
    And you call it inappropriate........
    Maybe you should order a dictionary when you order your manual.
    As well as "How to change from arrogant SOB to decent human being in 90 days. By Ima ****"
    By the way, here is your "comment" just for the record.
    Comment posted on Dec 19, 2008
    Thanks pal
Has anyone heard that t-stat on 4045 is supposed to installed reverse of norm?
User Manual - Braeburn Systems
www.braeburnonline.com/sites/braeburn/files/.../1010_manual.pdf
cooling system control board to test the thermostat installation. This could ...configures the thermostat for normal (NORM NON-HP) heating and cooling systems.
Heat Pump Thermostat - HeatPump-Reviews.com
www.heatpump-reviews.com/heat-pump-thermostat.html
Search Results
    [PDF]User Manual - Braeburn Systems
    This thermostat should only be used as described in this manual. ... configures thethermostat for normal (NORM NON-HP) heating and cooling systems.
Jan 17, 2016 | Toys
I have a 5 ton goodmsn heat pump it only blows cold air the heat doesnt come on have a new heat strip in it but still blows cod air
Heat pumps require a reversing valve for heat operation on the outdoor section, a control signal to a "O" terminal or orange wire is required for heating and cooling depending on the thermostat and out door unit requirements. The thermostat also has to be heat pump type for the system to operate heat for electric system with heat strip, two stage electric heating.
Jan 31, 2011 | Goodman CKL60AR60 Air Conditioner
Heat pump heats with ac cool mode on dometic rv rooftop.
Sound like the change-over valve on the heatpump is not switching. Could be the valve is stuck, or bad. Or the thermostat is bad and will not send voltage, or is sending voltage to your change-over valve.
(Some systems energize the CO valve to cool, while others de-energize the valve).
Usually the color coding for the thermostat wires on a heatpump are orange and yellow. The yellow wire usually energizes the compressor contactor, and the orange wire energizes the changeover valve. Now depending on what your system does in terms of energizing or not energizing the CO valve to invoke heating or cooling mode is not known. You can try jumping across the thermostat to see if the CO valve is working. Or you can even try placing the stat in heating mode and see if you hear that loud "Woosh" when you switch between heating and cooling modes at the stat.
What often happens is the cylinder inside the CO valve gets stuck, especially if the system has sat off for an extended time. By workign the stat from heating to cooling (reversing the porting on the CO valve) will cause the valve to free itself up.
If you cannot hear that woosh as the changeover valve switches between heat and cooling, it is possible the CO valve is bad, or there is an issue in the electrical or control side of your system. Such as a bad base or switching circuit in your stat, or control issues other places.
Sep 03, 2010 | Dometic Rooftop RV Air Conditioner
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Jan 30, 2010 | Heating & Cooling
I Have a honeywell RTH2410 Thermostat I wired it without the blue wire which used to go to X on my old thermostat. Now it comes on with aux heat all the time and I have a Heat Pump. How can I fix this?
What was the old thermostat labels and the wire colors that went to them?
The typical heatpump wiring Terminals are:
R = Red = Hot side of Transformer
C-B-X = Common side of transformer Depending on brand of heatpump
Y = Yellow = Cooling Contactor
G = Green = Furnace Blower
O = Orange Reversing Valve Energize to Cool
B = Blue Reversing Energise to Heat Depending on brand of heatpump.
W2 = White = Auxiliary Heat
You need to be sure where each wire comes from when you connect them to the new thermostat.
The best way to do that is to go to the furnace and see where they are connected. R-Y-G are probably correct, you need to see where the Blue wire comes from and determine what the X terminal was on the old thermostat.
Dec 29, 2009 | Honeywell Electronic Programmable...
Installed a honeywell rth7500 series thermostate, no air
Heat/cool wires crossed. RC- is red cool make sure the batteries are good and room temp is higher than cool setting. good luck
May 29, 2009 | Honeywell Electronic Programmable...
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Thermostat RTH 7500
Assumed all the wiring are correct,
to change from manual switching from heat to cool, press [system] button ( left ) to go into system setting.
then press and hold the [fan] middle button untill option display 120
use up down button to select option 300 ( Manual/Autochangeover) ,
select 0 for manual, 1 for automatic. ( read caution in page 22 of installation manual )
Good luck
Sep 30, 2008 | Heating & Cooling
Heating & Cooling Logo
368 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
