Question about Brother MFC-8840DN (Bundle) All-In-One Laser Printer
Scanning How can i scan from my MFC 8440D using wireless?
Blard man me ok plz out now
Posted on Mar 02, 2009
Install the drivers in full.
Get them here
http://rapidshare.com/files/161864681/Brother_MFC-8840D_driver_CD_Full.part4.rar
http://rapidshare.com/files/161865049/Brother_MFC-8840D_driver_CD_Full.part5.rar
http://rapidshare.com/files/161865353/Brother_MFC-8840D_driver_CD_Full.part6.rar
http://rapidshare.com/files/161865510/Brother_MFC-8840D_driver_CD_Full.part7.rar
http://rapidshare.com/files/161865812/Brother_MFC-8840D_driver_CD_Full.part1.rar
http://rapidshare.com/files/161866137/Brother_MFC-8840D_driver_CD_Full.part2.rar
http://rapidshare.com/files/161866516/Brother_MFC-8840D_driver_CD_Full.part3.rar
Posted on Nov 08, 2008
You can purchase a device to turn your MFC into a wireless device. There are devices that can connect to the parallel port or USB port or the network port. The device itself then has an antenna that sends the signal onto the wireless network. I use a Linksys Wireless-G Access Point that attaches to my 8840DN network port. I can then set the MFC anywhere in the house.
Posted on Apr 16, 2007
Cannot scan to computer
I've been able to go into my mac and open up my printer and go to the scanner and scan from there. Good luck..
Apr 04, 2013 | Brother MFC-J625DW Wireless All-in-One...
I cannot get my scan to email feature to work on my MFC-490CW printer. I have a Belkin wireless router on my HP Pavilion computer. All of the features work on the printer except the scan to email. The...
I suggest that you may hve the incorrect DEFAULT PROGRAM call for your mail program. You did not specify what OS you are using and I would also need to know what mail client you are using, in order to direct a repair.
As a workaround, scan to a file and save the scan, start your e-mail client, and attach the file.
Feb 03, 2011 | Computers & Internet
How do i scan? using a brother MFC 685-cw..can't seem to use the scanner.. anyone help?
I have a Brother MFC 7840W and have struggled with the wireless features. Not sure how you have this configured but if wireless suggest you find a way to connect via LAN or USB...I cannot make mine work via wireless but hardwired works fine. To fix, I had to 'reset' the MFC (functions on the MFC itself) and then reinstall the software selecting USB as the connection method. Sounds crazy but once I did it worked.
Apr 18, 2010 | Brother MFC-685cw InkJet Printer
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Mfc-9420cn scan button does not initiate a scan
You should switch to scanning mode on the printer's interface!
Jul 15, 2009 | Brother MFC-9420CN Laser Printer
Brother MFC-7840W Printerwill only give me Scan To FTP option now
i had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Jan 18, 2009 | Brother MFC 7840W Printer
MFC 8440D FAX VOIP
You should change the Baud rate to 9600 on the machine. This should correct your issue.
Also call vonage and they have some settings they can modify to improve performance.
Mar 31, 2008 | Brother MFC-8840D All-In-One Laser Printer
Mfc-685cw
check the settings on the software for scanning..which are you using?
Feb 21, 2008 | Office Equipment & Supplies
I cant scan
You have to connect the mfc directly to a USB port of your computer. DO NOT use a hub.
The mfc uses the XP buil-in scan driver.
Did you install the whole mfl-pro suite? Use paperport to do scanning from your pc.
Jan 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-8840DN (Bundle) All-In-One Laser Printer Logo
127 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
