Question about Brother Sewing Machines
How to thread machine
Pacesetter vx2051 given to me...I think it will still work but can't figure out how to thread it; I have had no paycheck since Aug 1 and cannot afford to purchase the manual...how about e-mailing me diagram or instructions as a sympathetic Christmas present? :-) Can;t blame a gal for trying, right?
  • Brother Master
  • 12,729 Answers
Was not able to locate any manuals for free. Unfortunately, free Brother manuals are pretty rare..
However, machines basically thread in a similar manner from model to model, so the following may be helpful:
How do thread my machine Brother
HINT: ALWAY RAISE the presser foot when threading the top thread and make sure you start out with a brand new needle in your machine.
How to Thread Brother Sewing Machine
how to thread brother sewing machine bobbin Google Search
Posted on Jan 21, 2018
    Top Expert:
  • Brother Master
  • 53,736 Answers
Try this
on your browser search bar type in---user manual for pacesetter vx2051 sewing machine--- and see if there is a web page with a pdf version down load
Posted on Jan 20, 2018
sir fixalot
  • 146 Answers
SOURCE: Looking for Instruction Manual
Here is a link to manual for sale on eBay:
http://cgi.ebay.com/Singer-Model-221-1-Featherweight-Instruction-Manual_W0QQitemZ290194053469QQihZ019QQcategoryZ38055QQcmdZViewItem
Posted on Jan 01, 2008
bargainbox
  • 1388 Answers
SOURCE: espree embroidery machine knots up the bobbin thread
If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Dec 11, 2008
SOURCE: I need to load the bobbin for my singer 247, I have no manual
I am a veteran seamstress and I may be able to help you. it sounds as though you just have the wrong needle in the machine or the needle is in backwards.. Machine needles are different lengths according to what machine it is. The needle could also be dull on the point. Try this and see if it helps. Also your local sew shop can help you no charge if you just go in and talk with them. The techs enjoy helping for the most part I have discovered.
Posted on Jan 08, 2009
SOURCE: threading instructions for the euro-pro shark mechanical machine
You can view the manual online at the euro pro web site. Although, I have the manual and I am having the same problem. It was working fine and now for some God only knows reason, I can't seem to thread it right again. This is extremely frustrating for me. The manual doesn't give written instructions there are just picture for you to use as a guide. Here is a link to the manual, I hope you have better luck than me.
http://www.euro-pro.com/europro/manuals/605.pdf
Posted on Mar 27, 2009
  • 139 Answers
SOURCE: singer 2732 sewing machine
Visit this website:
http://www.singerco.com/resources/threading.html
Posted on Apr 07, 2010
I have a Pacesetter, haven't used it in years. Think I have it threaded right, but the bobbin thread just stops me after a few stitches and I have a matted mess under the material
Sounds like not enough tension to keep the thread up. Make sure threading is correct, always consult the manual unless you are using the machine every day. Yours is an extreme version of figure 1.
Dec 02, 2016 | Sewing Machines
I broke the thread on moms Brother PS 1250 and I need to know how to re-thread it, please?
I've posted a link below of YouTube videos of several Bother machines; they should be similar in Threading.
Google
Mar 26, 2015 | Brother PS-1250 Pacesetter
How to adjust tension on Brother Pacesetter 8200
Is your thread new? sometimes if it's older thread it will break often, finally changed my thread and it worked fine.
Feb 13, 2015 | Brother Sewing Machines
Upper thread keep breaking
http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_PC_6000_EN_2572.PDF manual is at the above web site
Jan 26, 2014 | Brother PC-6000 Pacesetter
PE-3000S Pacesetter won't pick up bottom thread
try changing the needle
also rethread the machine
clean under the needle plate & in the bobbin area for loose threads or lint
if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
May 15, 2012 | Brother Sewing Machines
I need a manual for my Brothers sewing machine VX2051
On your cpu through the internet type, find manual for Brothers sewing machine VX2051; you should get a list of links to choose from. Select a free download or contact Brothers headquarters.
Apr 08, 2010 | Sewing Machines
How to thread a pacesetter sewing machine?
There are different models of the Brother Pacesetter.
If you try the Brother website you should be able to download a manual.
Apr 01, 2010 | Brother Lay-In Thread Serger Mechanical...
How do you thread a brother pacesetter 6000 for twin needle sewing
Two reels of thread on the top,make sure the threads go seperate sides in between the tension discs, thread both needles but remember not to put the stitch width more than 2.
May 02, 2009 | Brother PC-6000 Pacesetter
PACESETTER 1250
I found the manual on line and the other posts at fixya.com helped me solve the problem.
Feb 16, 2009 | Brother PS-1250 Pacesetter
Sewing Machines Logo
75 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
