Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
Tiffany Parikh Posted on Mar 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washer does not drain water
Start wash cycle, when cycly ended it went into rinse cycle without draining the water from the wash cycle.
  • Anonymous Mar 12, 2014
    water will not drain on the rinse cycle
  • Anonymous Mar 23, 2014
    water is draining out even when on wash - rinse knob is on
Anonymous
Level 2:
  • Expert 87 Answers
  • Posted on Jun 08, 2007
Anonymous
Expert
Level 2:
Answers
87
Questions
0
Helped
42769
Points
100
You have a sock in the pump. If no noise in spin you have a bad lid switch.
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
2helpful
2answers
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
'97 Frigidaire FWS235RBS2 Wash Mach does not drain after wash cyc
Happened to mine too. ended up being a clog in the strainer on the pump.
1helpful
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Two year old Whirlpool washer started failing to advance from the rinse cycle to the spin cycle a couple of weeks ago. However, the water would drain through and run until you manually advanced the system...
Hi, I just want clarification. Is the washer filling to a point when it starts draining the water before it starts to agitate? If this is the case, check the end of your drain hose and make sure that it is as high as the top of the washer. Make sure that where it goes into the drain pipe that it is a loose fitting so that air will **** back into the drain hose. Please let me know if I have given you the right information or if I have missed what you are describing so I can assist you further.
Thank
Vic
The washer will not drain to rinse.
have you checked the pump it could be blocked?
1helpful
Water not draining during rinse cycle
check the drive belt for the pump under the machine
4helpful
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Will not drain
Check your drain pump, it might disconnected from wash motor, or drain hole clogged.
3answers
GE WASHER WON'T GO THROUGH THE DRAIN CYCLE AFTER WASH CYCLE
ck wiring to motor be sure all conections are tight lid switch is ok since will agitate also ck control bd for connections most likely suspect all ck ok is control bd itself
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
