Question about Panasonic Lumix DMC-LZ2 Digital Camera
How do you take the memory card out?
How do you take the memory card out of the camera once it's already in?
  • egirlpower Dec 19, 2008
    Thanks! It worked.
  • dorothy_pang Dec 27, 2008
    I use Panasonic Lumix DMC-LZ2 for 3 years (didn't fall off and drop)
    When I used Marco, the camera suddenly can't focus and show
    "PLEASE TURN CAMERA OFF AND THEN ON AGNAIN"
    yesterday.
    Then, I tried all modes but it still shown it when I move the focus adjusment.
    Now, when I switch on the camera, the camera head will extend the most longer and can't turn inside (even off the power)
    I only can let the camera head to state inside within a secon in switching on, open the battery cover.
    playback is function normally
    have any method to reset the camera hardware?
  • 78 Answers
Push down on it,it should click"up",then simply remove!!
Posted on Dec 18, 2008
I have Norcent Xias digital camera and when I put in flash memory card "original or new" get message Card Error. What is the next step to resolve problem?
As long as you use a SD card it should work. But now most stores only sell SDHC cards and already there are lots of SDXC cards. Both won't work in the Norcent Xias.
Once there were 4 Gbyte SD cards now the 1 Gbyte cards are already SDHC, because they are faster and newer devices can use these.
Mar 01, 2015 | Norcent Technologies Xias DCS-760 Digital...
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
How can i transfer built in memory card to memory card if built in already full
Hi bacayemilita,
I think you meant that you need to transfer your images from your camera's built in storage to your external memory card.
Please follow the below steps :-
  1. Connect you camera to your computer via the USB cable and then switch your camera on.
  2. Once you switch the camera on you will find an option for mass storage mode , please select that option.
  3. Remember to remove the memory card from your camera while you do the above step.
  4. Once you select the mass storage mode , you will find a removable drive being displayed in my computer , in this drive you will find all your images, so all you need to do is copy them all to your hard disk drive.
  5. Now if you want to copy these images to your memory card , you can either do it via connecting your memory card to a card reader and copy the images from your hard disk onto it Or you can connect the camera while keeping the memory card in , and you will find another removable drive for memory card , when you select mass storage mode.
  6. When you find the drive , just simply copy the contents from your hard disk to your memory card's removable drive.
Hope this helps ..:) Your feed back would be greatly appreciated.
Jun 26, 2011 | Pentax Optio S4i Digital Camera
My camera says memory card is write protected, how can i remove this?
Hi, try to remove first the memory card inside your camera, most memory cards are inserted at the location of the battery also. Pull out the memory card after pulling out the battery. You can pull out the memory card by pressing it once and it should pop out automatically. If it's lose already, please check the sides of your memory card, there should be a small switch either color grey, orange or red and change the switch by clicking upwards or just the opposite side of the original place... the card then is not write protected anymore.
Jun 06, 2011 | Nikon COOLPIX L20 Digital Camera
When you get memory card error on every card you put in your camera, what needs fixing? The camera or the card? All 4 cards gave the same error. I already got all the pictures off of them and deleted...
You said it in the last seven words "deleted the pictures off the memory cards" Once the pictures have been downloaded to the computer Hard Drive you need to Format the memory card. Formatting a memory card is done in the camera it is to be used which brings it back to a clean surface and compatibility. Your manual said that "normally" formatting isn't necessary which is a pile the bull left behind. I could go into detail as to why format but I'm trying to keep this short/
Here is a diagram to show you where the "format" menus is and what to do with it.
Diagram
Cheers
Jan 18, 2011 | Panasonic Lumix DMC-FZ20 Digital Camera
When I start the camera, it says in red "this card
hi there...
i have once experienced the same as you
try to format it with your laptop/PC, then reformat again using camera option
if still don`t work, i assume the memory card is broken and you`ll need to buy new one
Jan 13, 2011 | Nikon Cameras
Pictures taken with camera and no memory card inside how to
There is a copy option on the playback menu.
This copies to and from the memory.
Feb 04, 2010 | Nikon Coolpix S210 Digital Camera
Format memory card on i534
Hi Mr Varshap4
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Nov 19, 2009 | Polaroid i534 Digital Camera
Dc-t50 does not have menu to cancel protect on memory card
http://www.rekam.ru/drivers/dcj01x.bin
Download the firmware above... Copy it to a freshly formated by the camera SD card..  hold the up arrow for all 3 100%'s  turn the camera on it takes 2 min
Jan 24, 2009 | Gateway DC-T50 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
20 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
