Question about Generic Memory 19-key USB Keypad and Calculator (CKP180N) PC Notebook
Keypad keys my 1 year old has pulled some keys from my keypad, I have spent ages trying to get all the plastic bits the right way!! I need help!! Please Thanks.
"quadratic function" diophantus , a greek
Let x be Diophantus' age when he died.
His son died 4 years before Diophantus (so Diophantus was then x-4 years old). His son lived half as long as Diophantus so when he (son) died he was x/2.
Diophantus' son was born when Diophantus was (x-4)-x/2 years old. That was 5 years after his marriage so when Diophantus married he was (x-4)-x/2-5 years old. We also know that 1/6 of his life was spent in childhood, 1/12 in youth and 1/7 as bachelor so (x-4)-x/2-5=(1/6+1/12+1/7)x.
Now you solve last equation:
  • x-4-x/2-5=11/28x
  • x/2-11/28x=4+5
  • 3/28x=9
  • x=9*28/3=84 years
Diophantus was 84 years old when he died.
Sep 27, 2011 | Office Equipment & Supplies
The sum of ages of marian, diana and carlos are 17. Two years from now marian will twice as old as diana. if carlos is half as old as marian four years from now. How ald are they now ? Pls show the...
Let m be Marian's age, d Diana's age and c Carlos age.
  • sum of ages is 17: m+d+c=17
  • two years from now Marian will be twice as old as Diana: m+2=2*(d+2) so m+2=2d+4 so 2d=m-2 or d=(m-2)/2=m/2-1
  • Carlos will be half as old as Marian 4 years from now: c+4=1/2(m+4) or c+4=m/2+2 or c=m/2-2
  • now: m+d+c=m+m/2-1+m/2-2=17
  • 2m=17+3=20
  • m=20/2=10 years
  • d=m/2-1=5-1=4 years
  • c=m/2-2=5-2=3 years
Marian is 10 years old, Diana 4 years old and Carlos is 3 years old.
I hope I helped :)
Sep 18, 2011 | Office Equipment & Supplies
Father is 3 times as old as his daughter.In 12 years father will be 1 year less than twice his daugthers age.What is their age?
So the father is 3 times as old as his daughter.
Let F represent the age of the fatherLet D represet the age of the daughter
So we know from the first sentence,
F = 3 * D
From the second sentence, 12 years from now the father is 1 year les than twice his daughters age,
First, lets assume it's not 12 years from now (to avoid confusion), we would haveF + 1= 2 * D
But since its 12 years from now, we have to add 12 to both ages
(F + 12) + 1 = 2 * (D + 12)
Let's simplify a bit,
F + 13 = 2 * D + 24F = 2D + 11
Now we have to solve these two equations together, we can plug the first equation into the second,
F = 3 * DF = 2 * D + 11
3 * D = 2 * D + 11D = 11
So the daughter is 11 years old, we can find out how old the father is by plugging into the first equation
F = 3 * DF = 3 * 11F = 33
So the father is 33 and the daughter is 11.
Jul 19, 2011 | Computers & Internet
Numbers 1-6 not working on Samsung Microwave
front key pad needs replacment. it fits like a sticker on the front panel. Before you can remove it, remove the outer cover and disconnect the ribbon cable.Once done, peel off old keypad from front and reverse proceedure with new one.Reconnect ribbon cable.
Sep 14, 2009 | Microwave Ovens
# keypad rubbing out
Yes, they are replaceable.The keypad cover peel off and the replacement cover sticks on where the old one was.Warning!! make sure you have a new one before you remove the old one.Good Luck
Apr 06, 2009 | Canon ImageRUNNER 1670F Copier
Garage door opener key pad not working
so i spent the better part of this morning trying to figure this same thing out... here's what I found.
You need to identify the serial number, which is found on the unit hanging from the ceiling... it will be like a 13953970. I found mine behind the lamp light protector thing. NOT the back with the stickers. 41A5021 is actually not the number that is important.
then go to www.managemyhome.com its a website ran by sears. you have to register, for free. then go look for manuals, in one of the tabs running across the top of the site is a choice for manuals. then search by Craftsman then enter the serial number.
then pull up the owners manual and check out the instructions.
** i found out that the old house i bought did not actually have the same keypad opener as came with the craftsman. so i had to closely inspect all sides of the internal keypad opener (not the one outside) and find another serial number. then i went and got the manual from www.managemyhome.com and realized i needed to add a new 9-V battery before I could proceed. So now i'm heading out to walmart to get that.
after a frusterating morning of service number and internet searches I hope after I get this damned battery the clouds will part and god will shine some luck on me.
goodluck to yourself!
Sep 07, 2008 | Sears Craftsman LiftMaster Chamberlain...
Black spots on plastic items
I have the same problem on my Bosch dishwasher Model # SHX33A05UC. It is about 6 years old. I have replaced three gaskets and it did not solve the problem. I am a 25 year mechanical engineer. I do not recommend anyone changing these gaskets on their own except for the long dishwasher door gasket (which goes along the top, left and right door edges) which is quite easy to replace. The other two gaskets, which were quite difficult to replace, were the gasket at the bottom of the dishwasher door and the sump pump gasket. I am still having the tar like black tiny dots depositing on my plastic tupper wear on the second shelf. I will likely not buy a Bosch dishwasher ever again. I will make my decision after hearing what Bosch tech support has to say about what I need to replace next. Could it be the rubber drain check valve not operating correctly? I need to find out. I have spent so much time trying to solve this black tar dot problem!!!
Feb 11, 2008 | Bosch 23 in. SHU33A Built-In Dishwasher
My microwave computer seems to be possessed
E4 normally indicates a problem with either the keypad or a sensor. Since the oven is resetting, it may be the keypad or even the control circuit board. Below is my info on keypads, which may help, followed by more info: You may also have a bad keypad, which in many cases can be replaced. KEYPAD TROUBLE A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. DISCONNECTING AND CONNECTING THE KEYPAD 1. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the control circuit board. 3. There are two tiny tabs (one on each side) on the hood of the connector that you can gently pull up on to unlock the connector. Use equal and gentle fingertip force when pulling up. 4. The old keypad strip will lift out. 5. Put the new keypad strip in, making sure both sides are down fully. (If you are not installing a new keypad, clean yours with a pencil eraser or a soft cloth and alcohol.) 6. While holding the strip down, push the connector hood back down to lock it. -- If your keypad (membrane switch) is bad, you should be able to get one here: http://www.samsungparts.com/search/search.asp If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you still have questions, please post again.
Aug 08, 2007 | Samsung SMH7178STD Microwave Oven
Microwave not working
For that model, the child lock is activated and deactivated by holding 0 then pressing 2. But that doesn't sound like your trouble. You may have a keypad which is defective, damaged or may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top, direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. If this happens it must dry out or be dried out, unless the moisture has gotten too deep. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If the keypad or controller has gotten wet, it can sometimes be carefully blown out with compressed air or heat. Another thing is to unplug the power at the mains for several seconds por minutes. Plug it back in and see if it works. A reset may do it. At power-up, the display should flash or show a text message. If not, a key may be stuck due to a foreign substance or a defective keypad. If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board. To check that, it will need disassembly, and we have *critical* safety & disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk 1. Be sure the oven is disconnected from the power line while you are taking it apart. 2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board. 3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector. 4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser, then with alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip. 5. Put the keypad strip back in, making sure both sides are down fully. 6. While holding the strip down, push the connector back down to lock it. 7. Try the keys again with the door closed.
Apr 23, 2007 | Samsung MW1030WA Microwave Oven
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
Generic Memory 19-key USB Keypad and Calculator (CKP180N) PC Notebook Logo
Top Generic Memory Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
