Question about BenQ DC C500 Digital Camera
Camera won't turn on ...just there is red lamp is workoing
Camera won't turn...just there is red lamp is workoing
  • 944 Answers
Here is the link to the user manual for your camera if you need it; ftp://213.61.96.30/camera%2fmanuals%2fdc_c500%2fdc_c500_um-english-cd-0822.pdf The red lamp, if it is flashing/blinking indicates that the self-timer function is on - check page 15 for how to turn it off. If the light is steadily on, and it is the battery/power status light, then the indication is that the battery is faulty or not charged - possibly the fault is with the charger, but more likely a new battery will solve the problem. To get a new battery, go to; http://support.BenQ.com and they should tell you where you can get one, if no luck with them, please post back with which part of Egypt you are in, and i can try to find you a dealer locally. Hope this helps :)
Posted on Apr 18, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Apr 18, 2007
    Sorry the manual link didnt post as a link - please just copy it and paste it into your browser.
My epson emp-74 won't show...the red light keeps on flashing
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd
panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Dec 06, 2012 | Epson (V13H010L32) Projector Lamp for...
Panasonic TV won't turn on, red led blink
The model indicated was a recalled set--all were supposed to be exchanged under a program Panasonic was forced to use.
The main reason was they were eating lamps up at alarming rates.
I would suggest the lamp (customer replaceable) be removed and inspected---it even if looks good may have to be replaced to see if it is the problem or not.
The lamp issue was caused by a bad Ballast that drives the lamp--kits were eventually made to cure this as the Ballasts were no longer available--rebuilt ones are but not easy to replace.
May 17, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Our tv won't turn on light blinks a couple minuate and then turns read again and lamp light flashes red
A possible bad lamp if not replaced recently or removed and at least examined. What is model number and what have you tried so far?
Apr 19, 2012 | Sony Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Everything was workoing fine. then one day no
if power light is on and no sound check audio jacks on amp and to speakers
Jun 06, 2010 | Kenwood KAC-7201 Car Audio Amplifier
BenQ DC C500 Digital Camera Logo
137 people viewed this question
Top BenQ Cameras Experts
Damen Wong
Damen Wong
Vincent_G
Vincent_G
Daniel Dollive
Daniel Dollive
Are you a BenQ Camera Expert? Answer questions, earn points and help others
