Question about Kitchen Ranges
Tappan Visualite electric wall oven - around 1960
Top oven has a preset cooking mechanism. I can't get top oven to lite because I don't have the dials lined up properly. Center dial is a clock (not working) a setting for "hrs to cook" & "stop". There is also another knob to the left of the clock which reads (I think) S C O M (4 settings). I can get the oven to work by trial and error - not suitable for holiday cooking. Has anyone ever encountered this problem?
Thanks
  • fraucoach Jan 02, 2009
    She said it all...I have the same exact settings and can only work it by trial and error.
  • AbbysNewHome Apr 12, 2009
    I also have a Tappan from 1960's w/ the center clock and two knobs. My problem is there are no numbers on the dials. I'm sure one is the temperature but I don't know what the other one does. No-one can help because I can't find a serial number. A replacement knob from the stores has temp and broil but if I have a separate knob for broil then the temps won't line up. Can anyone tell me whats on these knobs and where I can get replacements even if I don't have the serial number.
SolutionGuy
  • 331 Answers
SOURCE: the igniters wont light the burners
49er, if none of the igniter switches work you're on the right track. Follow those wires and you'll come to a "spark module". This will need to be replaced. Part number 74008821... lists at about $21.00. Good luck and let us know how it turns out.
Posted on Sep 27, 2007
IFIXALL
  • 868 Answers
SOURCE: Oven will not lite
Older is BETTER !! Replace the igniter,even if it is glowing
REPLACE it !
note:there is a 2% chance the safety valve is the problem.And I'll bet you ,you are in the 98% side on this one.EVEN THOUGH YOU SEE IT GLOW -----IF ITS JUST GLOWING---------GLOWING--------GLOWING---------it's gone ! !
Please Rate This & Thank You ! !
Posted on Jun 12, 2008
Illeagle
  • 525 Answers
SOURCE: maytag advanced cooking system
I attempted to locate a user's manual for you but your model number came back as invalid, please recheck your model number, and follow the link that I provided. This will allow you to download a manual for your range.
http://www.managemyhome.com/mmh/products/ManualSearch.action
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
Posted on Jun 18, 2008
SOURCE: Self-cleaning feature of GE Built-In Oven does not work
Simply set the Clock and Delay Start to the current time, then set the Stop Time ahead 3 hours. For example, if it is currently 8:00 then set the Stop Time to 11:00. The lights on the console will come on and the cleaning cycle will begin. At some point during the cycle when the oven gets hot enough, the lock mechanism is "fixed" and will not release until the cycle is complete.
Posted on Jun 28, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
Why does my broiler lite when I operate my oven?
There is a possibility that the switch is not wired correctly or perhaps your selector knob is on upside down i have seen this before.
Jul 15, 2014 | Tappan Ovens
Gas Tappan oven will not power up after power outage
make this test and use the multimeter. God bless you
No power
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
Nov 04, 2013 | Tappan Kitchen Ranges
Stuck oven light bulb
I use 2 sided tape to get a grip on the bulb. If it is really stuck and you end up breaking it, don't worry as it will be easier to remove the rest of the bulb with a pair of needle nose pliers.
Nov 23, 2011 | Maytag Amana 30 in. Electric Double Wall...
Trying to bypass electrical ignition on oven to
Hi, the gas valves on modern ovens are electrical and cannot be turned on without electricity. Only the cook top burners can be lit manually.
Jan 29, 2010 | Tappan Kitchen Ranges
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F8 CODE IS FLASHING, OVEN BEEPING AND TOP OVEN DOOR IS LOCKED
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
When burner is turned on, the "ticking" noise never stops!!!
You got water/liquid in the control switch,most the time you have to replace the switch,and most cook tops require the whole string of them be changed at once.That is all the switches are tied into /pre wired together.
Mar 26, 2008 | Tappan TGF363 Gas Kitchen Range
Kitchen Ranges Logo
1,272 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
