Question about Seagate 80GB 7200 rpm SATA/150 8MB Serial ATA HD REFURBISHED p/n ST380817AS (ST380817ASR) Hard Drive
SATA 80GB Seagate HDD
Hi, Please help with my 80GB SATA Seagate HDD.I have formatted it many times because of which it got dead slow.The drive complains bad sectors while booting.The software Active SMART also showed many ECC errors and some other errors. Sometimes it starts giving beep sounds while booting and stands still there. Sometimes heavy data transfer operations hang the HDD. Some folders got locked permenantly.When clicked they ask to format the disk.Is formatting many times the reason for all this ? Can I recover my HD to normal state?Please help me out of this. Satya.
    Problem Solver:
  • 7 Answers
When your 80GB SATA Seagate HDD complains of bad sectors while booting, this is a sign of a failing hard drive. Today's hard drives will actually self-correct a certain amount of bad sectors before you get any kind of error message. If you are getting "bad sector" errors, this is because the drive has so many problems that it can no longer self-repair. You asked if this may have happened because you have formatted the drive many times. No, bad sectors was not caused by formatting. Your drive did not become "dead slow" because of the formatting. It became slow because your cpu now has to do much more processing to "work around" the bad sectors on the drive. You also asked if you could recover your hard drive to normal state. Please understand that once a drive shows bad sectors, it will not be long before the drive fails completely, at which point you will no longer be able to access anything at all on the drive. No, this drive cannot be recovered. Instead, you should save all the data you can from this drive, and you should do this as soon as possible, before it fails altogether.
Posted on Mar 29, 2007
HEY DUDE SAME PBLM YAAR I HAVE THE DRIVE ALSO MAKES A LOT OF NOISE SINCE IT WAS NEW ,PERHAPS WE R IN SAME BOAT TELL ME WHEN U GET A SOLUTION
Posted on Jan 08, 2008
Can not detech
Good day!!!
please check the HDD itself if it is set on master?slave?
please change it to master..
if the problem persist just add a comment.
Jul 11, 2011 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
My Hdd Has Been Not Ditected
Sounds like your drive needs to be formatted, click the start icon in your taskbar then right click "computer" and select "manage" this will open the "computer managment" window from the list select "disk managment" and your drive should be visible in the lower list on the right. Right click and select format from the list. Hope this helps
Aug 26, 2010 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
Seagate ST3500630AS SATA 500 GB hard Drive
You will have to send it to a data recovery company in order to retrive the data sounds like the circuit board failed therefore the drive is not receiving power.Usually if this board is good you would hear the drive spin up.
Good luck
Oct 04, 2009 | Seagate Computers & Internet
Seagate SATA 80GB Master Drive and Seagate IDE 80GB Salve Drive
Dear,
You have to make IDE drive as slave. For this put the jumper to slave in IDE drive. Possibility of CMOS battery is rare, but you can confirm it by checking your system time in BIOS. If system time is ok then there is no problem in CMOS battery and you need not to replace it.
Thanks,
Rakesh Kumar
Jul 23, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
500gb seagate reading but not showing in my computer. help
Seagate Drive not being detected:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=201713&NewLang=en&Hilite=
If your drive is SATA drive, then you may follow the steps in the below link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=SATA_Troubleshooter_-_Serial_ATA_Data_and_Power_Cables&vgnextoid=e4644a3cdde5c010VgnVCM100000dd04090aRCRD
I recommend you to visit the below link that has information on similar hard drive issues in computer:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?SearchOperator=0&ssdFilterCommunity6=0&ssdFilterCommunity7=504
If the drive is not displayed in computer, you may follow the step My internal drive is not displayed in My Computer - 182615 in the above link.
Jun 19, 2009 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Seagate 80GB 7200 rpm SATA/150 8MB Serial ATA HD REFURBISHED p/n ST380817AS (ST380817ASR) Hard Drive Logo
259 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
