Question about Zenith DVT412 System
No power up just blink
After going on setup and change a few thing i try progressive scan to see what it does and I had from then on only a blue screen with video and hour on the corner sond background after playing with the remote blindly because nothingn will come on the screen nothong work so I unplug it for the night. now it won't even turn on and the light beside power is blinking. That's it. Is there anything we can do? Thanks for your help.
  • tep27 Jan 06, 2008
    I have the same problem. Any solutions?
  • cm81 Jun 29, 2008
    same problem here....i played with it and it worked for a while but i knew it was fragile so i left it on all the time but when it started to get hot i had no other choice then to turn it off again...and yes blinkin light is all it does now...
techman
  • 3130 Answers
SOURCE: Loss of Speaker Test, Progressive Scan option, FF/RW Scanning, and DTS Sound
First thing to try, would be to unplug all your equipment overnight to see if the microprocessors reset. If your still having problems , then you have a firmware problem and you should contact the manufacturer to see if its downloadable and upgradeable. Good Luck
Posted on Aug 13, 2006
SOURCE: Static/White Noise
Scroll down to the speaker set option. activate it then push the > button. You will see the test below the speaker diagram.
Posted on Feb 11, 2007
SOURCE: my home theater got stuck in progressive scan mode
I had this problem, it's a real pain. You need to turn the system on and goto Setup Mode, then count the number of tiems you would need to scroll down and reset it. You will see no picture, so you ahve to actually cound the number of clicks down and over, you are doing it blind, but it will work.
Posted on Feb 12, 2007
SOURCE: Progressive Scan Mode
Check for video out in the dvd setup menu, and set it for composite,
It may be set for component.
another thing to try is setting the the progressive scan option off in the setup menu, you wont benefit from it, but at least it might work.
if you already tried using the prog scan and your T.V isnt compatible, you'll need to reset. press stop to stop any playing disc, and press stop again holding it for 5 seconds to reset the system.
good luck!
Posted on Jul 09, 2008
  • 8 Answers
SOURCE: Sound but no picture. Not progressive scan issue I think.
Have you tried swapping the scart lead ends around, this might work.
Posted on Mar 23, 2010
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
My sanyo dwm-3900 is on progressive scan mode how do i fix this
If your DVD players is set to Progressive Scan Mode, tehn ther would be a light indicating it is so. The light is labeled P?scan on the bottom right side of your display window.
You can disable/turn OFF the P/Scan mode in the "Setup menu".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 11, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
good luck!
Jan 29, 2008 | Zenith XBS344 System
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
DVD player
unplug it and plug it back in and press the progressive button to turn it off, should work. Yeah that blue screen sucks, i would have thought you can get to the menu no matter what but that's sanyo for you, well most other brands also...
Jul 21, 2007 | Sanyo DVW-5000 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Aug 12, 2006 | Zenith XBS341 System
Progressive Scan
SOLUTION #1
SOLUTION #2
works with remote only
SOULTION #3
While Disc is Running,
By using remote control,
Press Stop Button once to stop the disc (Stop in Memory Mode)
Press Stop Button once again to go into Full Stop
Then, Press & Hold Stop Button for 5 Second or So.
GOOD LUCK!
koreanainusa
Jan 21, 2006 | Zenith XBS444 System
PROGRESSIVE SCAN STILL ON- BLUE SCREEN ONLY
Cause: DVD+VCR was turned off while setting the Progressive scan mode. Correction: Keep pressing the STOP button for more than 5 seconds.
Oct 17, 2005 | Zenith XBV443 DVD Player/VCR
Zenith DVT412 System Logo
48 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
