Question about Hawking (hfs5t-eu) Networking Switch
IP adress? - Hawking (hfs5t-eu) Networking Switch
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Actually it will display not your 12 digit MAC address, but your IP address; the information you wanted (ex: 192.168.2.1)
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 108 Answers
Dear sir
please do the following to know your ip address.
start>program files>accessories>command prompt
type ( ipconfig /all) it will display one 12 digit physical address. (ex: 00-11-22-33-44-55)
regards
murali
Posted on Dec 18, 2008
I P ADRESS FOR MIVAR TV
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Mar 01, 2014 | ip-adress.com
Can not find ip address on richo 1035. I tried to connect my richo 1035 with computers through internet. I did all to change ports on printer properties section. I am putting ip address of my service...
Connect the machine to a router or a switch with a network cable.
In used mode, under network settings - set the machine to DHCP, so it will get an IP adress from the switch/router.
Print out a network status page, and see if you've got an IP adress.
In the command window on your PC type: ipconfig/all and see the IP adress of your computer. Compare it to the adress the machine got from the router/switch and see if they are almost identical apart from the last digits.
Install the driver, and install the printer using device name, and you should be good to go. Or you can set the IP you got from the switch/router as a static adress, and install the copier using the IP adress.
Jun 27, 2017 | Ricoh Aficio 1035 Copier
My ip adress is gone of laptop how do i fix it
Normally IP Address is assigned by your router which then also provides gateway and dns settings. On the IP address screen, select Obtain automatically for both IP and DNS.
If this does not solve your problem, please explain fully what the problem is.
May 12, 2011 | ip-adress.com
IR 22 30:HOW TO PUT IP ADRESS? i whant to
the easiest way is to print out a function list on the copier it should give the ip address on the list then open internet browser and input the ip address in the browser nd change the ip address there dont forget to make the ip address static hope you come right
Feb 19, 2011 | Canon IMAGERUNNER 2230 Copier
Can you tell me what an ip addresse is im trying to connect to xbox live and it keeps asking for ip addresse
Every device connected to the public internet is assigned a unique number known as an internet protocol (IP) address. IP addresses consist of four numbers separated by periods(also called a 'dotted-quad') and look something like 127.0.0.1
since these numbers are usually assigned to internet service providers with region based blocks, an IP address can often be used to identify the region or country from which a computer is connecting to the internet. an IP adress can sometimes be used to show the users general location because the numbers may be tedious to deal with, an IP adress may also be assigned to a host name, which is sometimes easier to remember hostnames may be looked up to find IP adresses,and vice-versa. at one time ISPs issued one IP adress to each user. These are called static IP addresses. beacuse there is a limited number of IP adresses and with increased usage of the internet ISPs now issue IP adresses in a dynamic fashion out of a pool of IP addresses (using DHCP). these are referred to as dynamic IP addresses. This also limits the ability of the user to host websites mail servers, ftp servers, etc. in addition to users connecting to the internet with virtual hosting,a single machine can act like multiple machines (with multiple domain names and IP addresses).
Jan 30, 2010 | Microsoft Xbox 360 Elite Console
Check IP adress, Sub-net Mask and Gateway adress
open rum command and type command ......
after open command prompt ....
type ipconfig and enter......
ok
you see your ip address subnet...
Sep 02, 2009 | Linksys WCG200 Wireless Router
Cannot see server
check ipconfig if ur ip adress is correct configure Ip address statically but then be carefull that u dont duplicate another Ipadress already on network
make sure gateway ip adress is correct as well as dns server ip adress
try to add urself to the domain check if your pc name is correct
Sep 01, 2009 | Computers & Internet
Ip adress keeps failing...?
Are you sure nothing else on the network your using has the Same IP Adress. If anything does, This IP will not work.
Jan 04, 2009 | Microsoft Xbox 360 Console
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Hawking (hfs5t-eu) Networking Switch Logo
243 people viewed this question
Top Hawking Computers & Internet Experts
Marvin
Marvin
Steve
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
