Question about Samsung DVD-R155
Samsung dvd home theater HT d5610
I turn on my player, it starts searching for DVD and then says Protection mode and then says goodbye and goes off. THe Dvd signal comes on the TV but that is all . What is the problem ?
I am looking for and to purchase an antenna for my HT D5610. Thank you for any help you can provide me with.
Posted on Feb 01, 2009
    Genius:
  • 1,199 Answers
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
Posted on Dec 18, 2008
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
How do I shut of the Protection on the Samsumg HT TP-33 in order to play a DVD
If you mean the unit is self protecting due to a short or overload, disconenct all the speakers and see if that helps, then troubleshoot the cause. Otherwise, it needs service.
http://www.retrevo.com/support/Samsung-HT-TP33-Home-Theater-Systems-manual/id/357dj788/t/2/
Then there's this....
Copy Protection
Many DVD discs are encoded with copy protection. Because of this, you should only connect
your DVD player directly to your TV, not to a VCR. Connecting to a VCR results in a distorted picture
from copy-protected DVD discs.
• This product incorporates copyright protection technology that is protected by methods claims of certain
U.S. patents and other intellectual property rights owned by Macrovision Corporation and other rights
owners. Use of this copyright protection technology must be authorized by Macrovision Corporation, and
is intended for home and other limited viewing uses only unless otherwise authorized by Macrovision
Corporation. Reverse engineering or disassembly is prohibited.
Dec 26, 2010 | Samsung HT-TP33 Theater System
Why does the Samsung Home Theater DVD player display the word PROTECT then does not work?
if the speaker connections are not properly or anything wrong in dvd drive it goes in protection mode.remove all the speakers and insert the cd and see if it works with headphones. if it works check all the speakers one by one
Jun 04, 2010 | Samsung HT-DB120 System
When I put on my DVD player, it says "hello, DVD, LOAD, PROT" and turns off...
I assume "PROT" means some sort of protection mode. I would check to see if any of your speaker wires are crossed at the speakers or the receiver. If not you may have shorted something internal.
Mar 18, 2010 | Samsung HT-WP38 System
Need help with Media Player
WMP 11 will _ONLY_ install on a "genuine" copy of Windows. The only ways out of the "PROTECTION" error: * start in Safe Mode, and use System Restore to go "back" in time to a date before the problem started; * reinstall Windows from *GENUINE* media.
Dec 25, 2008 | Samsung HT-TX72 Theater System
Protection mode
the protection feature is for shock protection and will go off if one of the speaker's positive and negative wires are touching check your wiring
Nov 11, 2008 | Samsung HT-SK5 System
Guru
I was moving around my large woofer speaker last night and then all of a sudden the unit went into protection mode. I tried all the various solutions posted on here and nothing worked. Then I went back to my speaker connections on the woofer and unplugged them and plugged them in again and it seems to be ok now. Very annoying problem. Can I suggest unplugging all the speaker cables and replugging them back in. Also another solution may have been holding down the power button when powering up the unit. Give all the above a try.
May 22, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Apr 14, 2008 | Samsung HT-DS610 System
Samsung DVD-R155 Logo
506 people viewed this question
Henry  Thomas
Henry Thomas
