Question about Insignia IS-LCDTV32 32 in. Television
I DID NOT GET A MANUAL WITH MY 50 TV I WANT TO WATCH A DVD, HOW DO I HOOK UP WIRES AND WHAT SETTING ON REMOTE GETS ME THERE?U
    Genius:
  • 1,199 Answers
OK dvd output red/white/yellow cables into TV input1 red/ white/ yellow or anyinput then on remote select that input and you are ready!
Posted on Dec 18, 2008
How do i set my Toshiba ct-90157 remote to watch dvd's
Most DVD players are connected to one of the rear audio/video inputs--hook to that input and select it on the TV--then hit play and if connected correctly you will see the movie.
May 20, 2012 | Toshiba 50A50 50" Rear Projection...
Great picture but really loud static when watching dvd
Hook the DVD to another TV set, this will prove if the player is the issue or original TV
Mar 19, 2012 | Yahoo Diamond Vision DVDC803-04 DVD Player
Where can i find the volume on the remote for dvp3150v/37
Your DVD/VCR player does not have a volume but your TV will control the volume for it. If you do not hear any thing is because you did not hook up the TV right.
how to hook up a DVD player to a TV - http://www.youtube.com/watch?v=fVWE4_Vyesg
May 06, 2011 | Philips DVP3150V/37 DVD Player/VCR
The screen is black with Video1 in the upper right hand
Press the INPUT select button on the tv or the remote until you get back to TV mode.
Or leave the setting there and hook up a DVD player to your tv and watch a movie.
Good luck.
Apr 08, 2011 | Emerson CR202EM9 TV
When i load a DVD, I get a split screen and a large PSCAN!
Probably fix it with the remote. Look up progressive scan in your manual, and turn it off.
Apr 29, 2010 | Sceptre X240BV-FHD LCD TV
Hooked dvd player up to my olevia tv and don't know what channel to set tv on to watch video. checked all the channels - can't find movie. do i need to change a setting?
U setup ur DVD player in what format?Set it up with a one cable call HDMI?Or u use a RCA cable YELLOW.RED,WHITE to hook it up.The movie play,u push the button on ur remote said INPUT go down INPUT said 1,2,3 so on.If hook it up right the movie,should play in one of this INPUT said 1,2,3 so on.
Apr 02, 2010 | Olevia LT27HVX 27 in. LCD Television
Im trying to set up my tv, it was given to me as a gift, my uncle was using it it works i can change the channels but when i try to work my dvd player with it, only the audio comes on the screen stays...
Please few things...
1- Make sure audio and video wires are hooked correctly in AV input of tv and you selected that AV input in tv with its remote.
2- Also check your dvd has not been set on progressive mode if you hook dvd player through yellow-red-white wires with tv.
3- if dvd player is set on progressive mode, then hook it with tv by component video input, red-green-blue for video and red-white for audio.
Hope this info will solve your problem.
Thanks.
Mar 17, 2010 | Toshiba TP55H60 55" Rear Projection...
I have a Spongebob tv/dvd player. When trying to
I looked through the manual and didn't see anything either. I assume that you are hitting the TV/DVD button and setting it to DVD when you want to use the DVD. Does the remote do anything besides turn the TV on (change channels, etc.)? Hope this helps and good luck!
Mar 15, 2010 | Emerson SpongeBob SquarePants TV
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Hook up vcr
Unhook the dvd cables from the AV1 ports on the tv. Then hook these DVD outputs to the inputs on the vcr. Then hook the vcr outputs to the tv inputs (AV1). The tv and the vcr must then be set to channel 3 in order to watch the dvd (and possibly also some menu settings such as setting everything to "component video" and/or setting the tv/vcr button to "vcr. Also set all "3 or 4" switches on the back of all equipment to channel 3. Also, don't forget to go into your tv menu and choose AV1 when you want to watch the dvd and/or the vcr.
You can also try connecting your dish to the vcr and then the vcr to the input on the tv where you HAD the dish connected. There are several combinations you can try, but just remember to always put output cables to the INPUTS of the next piece of equipment in line, and set your menu settings appropriately on all equipment whenever you change from one machine to the next.
If all this fails, then here is a 100% positive solution. Buy an "A/B" switch. It has two inputs and only one output. You could leave the dvd connected as is and connect the dish and the vcr to the two inputs on the A/B switch. Then hook the one output of the A/B switch to the tv. When you change the position of the A/B switch back and forth, you will be changing over back and forth from dvd to vcr. You can move the A/B input selection switch manually or you can buy a remote controlled A/B switch and do your switching with the remote that comes with the switch.
Keever
Mar 04, 2008 | LG 42LC2D 42 in. LCD HDTV
Insignia IS-LCDTV32 32 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
