Question about Frigidaire FGB24S5A Gas Single Oven
Co smell during oven use
I just purchased this oven recently and found a strong CO smell when i started the oven but within 5-10min the smell had reduced. What is an acceptable co reading when using the oven? Should it change from the start to the finish? Where could i get an service manual?
  • glensamm May 11, 2010
    You are not smelling CO because CO has no odor. I assume you mean you are smelling natural gas? Sounds like the oven is slow to light. After it lights the smell should slowly dissipate to nothing.
    Scholar:
  • 93 Answers
What you are smelling is the protective grease against rust or corrosion that came originally with your oven. the odor is normal if you are just purchase the oven.
Posted on Feb 16, 2009
Strong gas odor only when oven is in operation?
If you're talking about the acrid smell immediately after starting the oven, that's aldehyde gas, a byproduct of cold gas combustion where the flame contacts the cold metal oven surfaces. That smell should disappear within the first minute or two, and it's entirely normal for a gas oven. If you're talking instead about the smell of fuel gas, then your burner may need to be adjusted; it may be running much too "rich".
Aug 23, 2014 | Electrolux Ovens
Noxious oven smell
Your oven needs a good clean up and so it is important that a good cleaning agent is used. Also check if there is chance that insects or rats have been caught inside and so if the smell is from the outside you need to open the oven covers to clean and detoxify.
check this link for tips:
http://www.espares.co.uk/advice/cookers-and-hobs/a/1/1335/how-to-clean-your-oven.html
Dec 09, 2011 | Ovens
What kw is my leisure cuisine master 100
If this is the RCM10CR model with electric hob and oven than it has a maximum rating of 13.8Kw (Page 6 of the manual, a pdf of which can be found here: http://www.leisurecp.co.uk/upl/31115-RCM10CR.pdf )
If it is the dual fuel RCM10FR then it has a maximum rating of 7.7Kw (page 6 of the manual, a PDF of which can be found here: http://www.leisurecp.co.uk/upl/55403-RCM10FR.pdf )
Jul 28, 2011 | Ovens
I used the oven at 425C for about 30 minutes, turned it off, took the food out, left the door open (the fan and light was on. During dinner, we smelled a strong chemical smell, like melting plastic or hot...
your mostlikley correct on the buring wires. The only thing that can be done at this point is to unplug the machine and start tearing in to it to find the bad wires.
Jan 08, 2010 | Whirlpool RBS275PD Electric Single Oven
My frigidaire ES400 gas range is giving off a sooty smell and high levels of CO that fluctuate from 23ppm - 118ppm (FD CO METER). what is the possible cause and how can it be repaired?
Air intake needs adjustment. Remove bottom drawer, there is a gas valve and the burner attached to it. Loosen small screw on the burner and turn the air baffle to let more/less air in. If not sure what you're doing - call a repairman.
Also make sure not to cover any vents on the oven bottom with foil, as some usually do.
It also can be that the burner holes need cleaning
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Ge gas oven
Remove the burner tube that you said has soot on it and clean it out. This will give you a cleaner burn.
Jul 20, 2008 | Ovens
Oven is noisy
next itme you get an authorized co. to come look at it ask them to call the "techline", f&p has an excellent tech resource hotline for us tech ive never called and had them not at least lead me in right direction.
Feb 27, 2008 | Fisher and Paykel AeroTech OS302 Electric...
Gas Smess
the gas might be too high, try turnin it down, or their is a falt with the oven
Jan 13, 2008 | Ovens
Frigidaire FGB24S5A Gas Single Oven Logo
384 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
Craig Butler
Craig Butler
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
