Question about Milwaukee 6310 22 18 Volt 6 1/2 In. Circular Saw With Two Batteries, Charger And Case
Milwaukee universal battery charger
My (2) 18volt Milwaukee Tool batteries will not come up to charge.
I believe it to be the charger. While the red light does come on the fact that neither battery will charge make me think its the charger. This all happened recently as I have had no problem then all of a sudden I do. I don't want to buy a charger if its the batts or visa versa. How can I test my charger to see if it is the culprit? Thanks Mike L
  • David Ford
    David Ford May 11, 2010
    Usually if the light comes on the charger is working. How old are the battery's? There is a date code on the housing of the battery. You can check the voltage in the battery with a volt ohm meter but the charger would require a demand for output to come up to max voltage. Let me know
  • 15,935 Answers
Check the voltage of the batteries before charging. Place on the charger and wait 1/2 hour or so, then recheck voltage. If it has not gone up, your charger is at fault.
Posted on Dec 25, 2008
How to determine positive & negative terminals to jump-start batteries/charger for Milwaukee 18 volt batteries and power-plus 9.6-18volt universal charger
Put a meter across the terminals the red is positive the black neutral if you get a positive voltage you have them the right way round if not you'll get a negative voltage.
Nov 23, 2016 | Cars & Trucks
My charger will not turn on nor charge . Milwaukee 48-59-0255....
The unit has a fuse mounted inside on the board. If you don't know electronics, I would replace the whole charger.
May 24, 2015 | Milwaukee Tool Milwaukee 48 59 0255...
Milwaukee M18 18v lithium ion battery will not charge.
there is no fix for lithium ion batteries , JUST REPLACE
Dec 17, 2017 | MILWAUKEE ELECTRIC TOOL CORP 48-11-1828...
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
I have 28v milwaukee tool kit and the batteries, both of them, went out at the same time. Strange! Upon charging the light on the charger blinks red and green. The batteries will not charge. Whats up with...
you can try and unplug the charger for a couple minutes and then retry. I have a LiIon at work and sometimes it does it also, if not then the batterys would probably be bad, I would contact Milwaukeetool.com and see about warranty replacement for these. They have a good warranty on the newer products.
Oct 28, 2009 | Milwaukee Tool Milwaukee 48 11 2830...
Milwaukee 18v battery
No, it's showing that the battery is either not taking a full charge or the charger is not charging the battery properly. Find a Milwaukee service center, they will check them and most likely replace one or the other.
May 27, 2009 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
V28 millwaukee battery problem
These batteries are fully warrantied for two years or 1000 charges,whichever comes first. On years 3-5 the battery is pro rated until 2000 charges. This applies to the v28 and v18 products only. The warranty his handled through the local Milwaukee Service Centers.
Nov 18, 2008 | Milwaukee Tool Milwaukee 48 11 2830...
Milwaukee 6310 22 18 Volt 6 1/2 In. Circular Saw With Two Batteries, Charger And Case Logo
1,602 people viewed this question
Top Milwaukee Saws Experts
Navin Sharma
Navin Sharma
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
