Question about Dyson DC17 Animal Bagless Upright Cyclonic Vacuum
On/off switch is faulty
I have to hold the power button down and keep it down to vacuum.
i feel the switch is bad
any ideas?
  • 1 more comment
  • daxz2 Dec 20, 2008
    id like to purchase this switch
  • Anonymous Dec 24, 2008
    I have the same problem and will need to purchase a switch. Where should I try to order one in the United States?
  • feedman72 Jan 05, 2009
    On / Off switch will only work if you hold it down while use the unit. It worked fine one minute, then was not working the next. Unit is about 18 months old.
I just fixed my Dyson DC17 last night with this same problem. You will need a T-15 Torx screwdriver and (optionally - this just makes part of it easier) a small flathead screwdriver.
Pull the extension hose out to expose the area behind the power switch. There will be 2 small screws there. Unscrew them with the Torx screwdriver. Next there are 4 plastic tabs that need to be pushed in (this is where the flathead is helpful, but I was able to do them with just my fingers). When you push the tabs in, you can remove the switch cover from the front. (I also removed the dust collection container) You should see two small black boxes with a small reddish-colored switch on top - these are the switches. One is for turning the brush on/off (on the left, as you face it) and the other is power (on the right). Slide the black box for the power switch out of it's position. This may not be everyone's problem, but my switch apparently had something inside it that was stuck. As it is opaque and had no obvious way to open it, I can't say exactly what was wrong. I just flicked it a few times with my finger until the switch on top popped up. After that, when I pressed it down, it clicked into place. Pressing it again made it click out of the held position. Put everything back together and you should be good to go.
Posted on Jan 22, 2009
  • rexerin Jan 22, 2009
    I feel I should add the obvious comment that you should of course unplug your vacuum before doing anything to it!!
  • 10 Answers
Here are some photos to assist with the dissassembly/identification of the switch issue:
on/off switch is faulty - f6e9a39.jpg
Posted on Jul 28, 2010
I must have gotten lucky.
I accessed the power switch as Rexerin suggested and saw the power switch partially depressed - not on, not off.
I simply used the small screwdriver to lift it straight up, and it clicked.
It works fine, once again.
Thanks for the instructions, Rexerin.
Posted on Dec 12, 2009
    Problem Solver:
  • 7 Answers
HI,
I CAN SUPPLY SWITCH FOR £3 IF REQUIRED OR IM HAPPY TO CHANGE SWITCH FOR YOU IF YOU SEND UNIT TO ME.
REGARDS
DAZ
DYSONLOGISTICS@AOL.COM
Posted on Dec 18, 2008
  • DARREN JACKSON
    DARREN JACKSON Dec 23, 2008
    HI, YES THE SPRING WITHIN SWITCH HAS GONE AND A NEW SWITCH IS REQUIRED, PLEASE EMAIL ME DIRECT AT DYSONLOGISTICS@AOL.COM IF ANY CHEAP SPARE PARTS ARE REQUIRED
    THANKYOU
    DAZ
We all of the sudden have to hold the power button down to turn it on. As soon as we let go of the power button, the vacuum shuts off.
It sounds like the actual switch in the unit has failed. The switch has a spring in it that keeps it in the on position then pushes it to the off position when it is hit again. If you can get to it, you'll be able to check it out yourself and Bissell will probably send you one to replace it.
Gary
Jan 24, 2011 | Bissell Healthy Home HEPA Bagless Upright...
Bissell 5770 vacuum power won't stay on. The power will only stay on if you hold down the button the whole time.
I just had this happen to me. I took the top part of the vacuum off, unscrewed all of the screws from the top piece and opened it just enough to pop off the plastic red power button. Then I pressed the switch mechanism up and down a few times to reset it and put it back together. Turns out it didn't actually go bad.
Feb 28, 2010 | Bissell 5770 Healthy Home Bagless Upright...
Dyson start button will not stay on. I have to
those switches go bad all the time. replace the switch and it will be fine. let me know if you need the switch
Jan 03, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The 'on' button isn't working/sticking
The ratchet mechanism within the power switch has failed.
There is no "fix" for this other than to repalce the switch with a new one.
If you have good DIY skills and tools, and feel competent to work on electrical devices, then it is possible to do this yourself, however Dyson dont make it easy !
The plastic switch covers (the bit you actually press) are normally held in place by a hidden plastic tag that is released using a narrow, flat tool such as a very small screwdriver or flat file. If you look very carefully at the switch cover, you should be able to see a very small "slot" on one side in to which you place the flat tool and "feel" for the tag. Once the swicth cover is removed, you can then access the switch.
Replacement switches are normally available on eBay.
If all this sounds a bit daunting, take it to a repair shop, or call Dyson helpline.
Oct 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The power button has to be held down
Hi there SmartAlec from nelsonvacuums.com.au here.The switch is faulty. Nothing short of replacing it will help you out. I can supply you with a switch if your in Australia just call me on 0269215200. there is a guide of hoe to fit it on dysonmedic.com. Hope this helps regards Alec
Aug 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Power switch will not engage.
Possibly the micro switch is faulty or the switch isn't in its proper position in the machine. It could be a cable problem too. An electrical continuity test (with the power off) should prove where the fault is. hope this helps.
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
On switch will not stay down or on
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great, it should now stick when you press the power button. Replace it and reassemble, otherwise you'll need to get a new switch.
May 21, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Power Button Problems
Hi.
Sounds like the switch is faulty & will need replacing.
http://dysonmanuals.llc.nu/
Chris.,
Jan 08, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC17 Animal Bagless Upright Cyclonic Vacuum Logo
915 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Manchester Vacs
Manchester Vacs
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
