Question about Northstar Generator 13 Hp, 8000 Watt, Trifuel
High voltage low cycles
I have a 8000 watt generator with high voltage low cyles
  • 1 more comment
  • rbhawaii Apr 24, 2009
    The voltage varies (widely) from 40 to 170 volts depending on engine rpm.
    Does the engine rpm alone determine the voltage?
    Do I just need to adjust the voltage by adjusting the rpms?
    Isn't there some kind of a regulator?
    Could that be broken?
    I'd love a "service" manual!
  • rbhawaii May 11, 2010
    I now understand that rpms determine voltage, thanks!
    However, when I get the genset to the proper output voltage, and it powers things as it normally should, the rpms are about 7200 rpm. That is twice the "normal" speed.
    Should I test the two diodes and varistors? How do I do this?
    Can I test them in place? Or should I just replace them?
  • Anonymous Mar 26, 2014
    low voltage when running
    President:
  • Northstar Master
  • 1,388 Answers
I worked at a tool rental center while going to college and learned how to service generators. Most appliances/tools require 50 to 60 cycles at 110 to 120 v. Your engine was designed to give maximum horsepower at 3600 rpm. Adjust the engine speed to produce 60 cycles and the engine should be at 3600 rpm and producing around 120v max. (Some special generators were designed to produce 230v 180 cycles, check manual) If your generator incorporates capacitors check them for at least 95% of printed uf value. They should be removed from circuit for testing. If there are two caps and one is weak make sure the new cap reads close to value of remaining cap. Finally there is usually a voltage regulator that varies the power to the armature magnet trying to maintain steady voltage depending on amp draw and engine condition. This regulator has no adjustment and is pass or fail type of item. Good luck, enjoy
Posted on Dec 18, 2008
Why won't my stanley 8000 generator put out power?
You have to be missing a switch to turn on the power outlets once it is running. That or a breaker needs to be turned on.
Jun 01, 2014 | Stanley Portable Generator: 8000 Running...
9000kw winco generator
varying load causes varying operation...= normal
i.e: generator reacts via voltage regulator to compensate amp draw.
Mar 01, 2014 | Winco Hps 9000 Ve 8000 Watt Tri Fuel...
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Photocopy canon not working ido why irc2380i
The problem with using a generator with a copier is that you are not using a constant wave length & a constant voltage. It is not a constant and level voltage as compared to a outlet. Also, there may not be enough watts. Copies today need a constant watts & voltage to work correctly. The PCB are very sensitive to any voltage drop at all.... Mostly 5 & 12 & 24 volts DC. A generator dos not produce a clean AC voltage. It's OK for a light bulb or a frig or micro wave...... Good Luck
Dec 19, 2012 | Office Equipment & Supplies
Is it possible to lower the output voltage? My unit is running closer to 127vac?
The voltage runs that high when there is no load so that as you load it the voltage will not dip too low...usually the higher voltage will give less trouble then low voltage will.. you also will use less amps. to run anything at a higher voltage... this places less stress on the generator...
I would not mess with it...when it is fully loaded you will be down under 120v
heatman101
Sep 11, 2011 | Briggs & Stratton Power Products 5,550...
My GE White Spacemaker Microwave just stopped heating-you hear the motor running but the light inside grows bright to dim by a few watts while going thru any cycle of heating. Any answers?
The magnetron has probably failed, there are also two other parts that can be a factor, the high voltage capacitor and diode, the high voltage is generated by these items which in turn heat the food.
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
THE VOLTAGE COMING FROM THE GENERATOR IS NOT RIGHT. iT WILL BLOW A LIGHT BULB INSTANTLY
Connect a voltage meter to the 115v plug and measure voltage. If too high, adjust governor spring tension to compensate. Your engine developes max horsepower at about 3600 rpm. At this speed the generator should be producting 115v at 60 cycles. Good holidays
Dec 17, 2010 | Porter Cable PorterCable BSI525W 5250 Watt...
Briggs and stratton 8000 watts generator, the output of the 120 is only 102. How do I adjust the output?
Voltage is adjusted by increasing rpm of engine. Use meter with Hz setting and try to adjust to 60 cycles and check voltage to be at about 115-120. If engine is turning 3600rpm/60 cycles and voltage is very low, then problem is most likely with brushes/ commutator rings, or voltage regulator. Some voltage regulators have an adjustment screw to bring voltage up/down (adjust to proper rpm/cycles first). Good luck
Sep 09, 2010 | Briggs & Stratton Electrical Supplies
Buffalo tools 4,000 watt generator
wow, that is high, i would think voltage regulator is faulty also
Aug 17, 2009 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
Northstar Generator 13 Hp, 8000 Watt, Trifuel Logo
449 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
