Question about Epson Stylus C66 Inkjet Printer
Epson stylus c66
I changed the ink cartridge on my epson stylus c66 and now the ink button and the middle button keep flashing simultaniously, how can i resolve this? i have tried turning it off and on but to no avail.
  • 1 more comment
  • Anonymous Dec 03, 2007
    changed ink cartridges now now reacting at all to command from computer when i press PRINT??
  • psrmidi Jan 13, 2008
    I have the same problem and the cartidges are locked over to the right with the two red lights are flashing constantly, I have tried the printer on an other computer and the same thing is happening.
    vince_cochran@psrmidi.fsnet.co.uk
  • Zambo Jan 30, 2008
    Ink Light and Paper Lights Flash on and off Alternately.
    ERROR MESSAGE SAYS 'Parts inside the printer are at the end of there Service life' MODEL; EPSON C66
    Have tried various holding down these INK and Paper buttons, turning off holdung them etc -- no joy.
  • 63 Answers
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Posted on Feb 14, 2008
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
I recently replaced an ink cartridge on my Epson stylus C66 and now the ink light and paper light are flashing on and off in turn and I can't get the printer to work. Do you know if there's an easy way to...
yes, this means that the ink waste counter is already in its peak and you need to reset it. try to download the inkpad reset utility through your computer. you will know all of the details from there on once you read them.
it would be www.epson.com/ipr
Sep 23, 2009 | Epson Stylus C66 Inkjet Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
My Stylus C66 won't work.
You have to replace all ink cartridges, it is somekind selling trick. I have epson printer too and it wont work if you replace just one ink, and i have 6 ink cartridges :D
Jul 06, 2009 | Epson CX8400 All-In-One InkJet Printer
Changed ink cartridges printing all blank old ones work ok any help
did you remove the tape seal over the ink port of the new cartridge?
are you getting any error messages?
did you aline the printer in the printer tools?
just some things to check
May 13, 2009 | Epson Stylus C66 Inkjet Printer
New cartridges not printing all blank
clean also the tab circuit to the printer maybe it suffered loss connection..
________________________________________________
unplug and plug your printer...and
try to wipe the cartridge on a wet cloth ..to determine that there is a ink going out on it...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson stylus c66
The Waste Ink Pads are saturated and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the red lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
The C64/66 service manual can be downloaded from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Should you decide to have a go at changing the waste ink pads, let me know and I can supply some notes on opening the case - it's a pig and the service manual is not that helpful.
Oct 22, 2008 | Epson Stylus C66 Inkjet Printer
Colour cartrige not work epson stylus c66
If the red light is flashing it means one of your inks are low
Nov 02, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Inkjet Printer Logo
411 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
