Question about HP Cameras
HP Digital Frame DF820a4 Pictures are not supposed to repeat until all have been displayed, but many repeat 3 or 4 times while others never show.
Agent Jason
  • 78 Answers
SOURCE: Download from PC to HP photosmart 435
Hi kearle,
You may find it easier to purchase a media card reader for transferring the files. This is a small device that allows you to connect the media card to your computer like a drive, thus allowing you to move files onto the card.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 20, 2008
SOURCE: Digital Labs Digital Photo Frame K101
Go to Menu > Custom Setting > Repeat Mode > All
Posted on Oct 09, 2008
  • 5 Answers
SOURCE: Displaying pictures Sunpak 7" Digital Photo Frame
This can mean many things. Pictures don't fit, Wrong file type e.g .png .jpeg .gif. Or has no more pictures to display.
Posted on Dec 20, 2008
benj888
  • 47 Answers
SOURCE: Pictures don't fill screen on Kodak M820 Digital picture frame
Because a digital photo frame's display ratio doesn't always match the original picture ratio, some pictures cannot be displayed in a satisfactory manner. For example they may be rendered too small, with black borders, or they may be automatically zoomed-in and randomly cropped.
With a computer, this issue can be resolved by using generic photo editing software like Adobe Photoshop, or specialized software like DPF Manager, Digital Frame Master or FrameSize, to properly crop the pictures before transferring them to the digital frame. Without a computer, there is no other option but manually deleting incompatible pictures by using frame's built-in functions.
Also, check the settings and try the "Fit to Screen" but, with some models the width of each landscape image is stretched to achieve an aspect ratio of 16:9, which results in noticeable distortion.
Posted on Jan 04, 2010
benj888
  • 47 Answers
SOURCE: How can I display pictures in "random" order on my digital frame?
Go back to the Home screen and go to the Settings. Select Viewing Options and activate Suffle/Random.
Can't get any of my personal pictures to show up on the digital picture frame at all
Check the max resolution of you pic frame (800x600), you may have to resize your pics down in res until they display. Take one pic that will not display and reduce the size 6 or 7 times on a memory card.( ... Make it a litter smaller each time) Then load and show each one until it is displayed. You have found your target size...
Jan 04, 2014 | VistaQuest 8" Digital Photo Frame
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Whenever I load photos onto my photo frame from the PC, they all seem to transfer just fine. But then when running the slideshow, not all the pictures are showing up. When I go into the photo menu on the...
The issue may be due to the file types of the pictures you are sending to the frame. You did not include the model number of the frame, so I can't be sure of the file types it can display but generally, JPG file types enjoy the most compatibility on such devices.
You should determine the file types of the images you are sending to the display. While displaying the slideshow, make a note of an image that displays properly. Look at the the image on your computer and check the file details to learn which file type it is. Play the slideshow on the frame and double check as many as you can against the list / thumbnails on the computer. After a short time, a trend show be visible. You may find that JPG and GIF files display properly, but TIF and others do not.
If you want those pictures to display, you'll have to convert them to one of the file types that does display. If you're finding that only some JPG (or other displayable file type) do not display properly, you'll have to see what is different. Sometimes, very large files may not display correctly, or it may have "too much color" information (they might be a 16 bit graphic or 16 million colors instead of an 8 bit graphic or 256 colors), or some other issue that isn't readily apparent. You can try resizing or converting to yet another format that is supported by the display (GIF for instance).
This is a starting point - hopefully you'll find the issue within one of these suggestions. Good luck! Please rate my reply - thank you.
Feb 24, 2011 | Philips 6.5-Inch Digital Photo Frame...
How do we speed up the viewing of pictures on our digital picture frame? thanks.
Go to the Settings > Viewing Options > Select Slide duration - specify how long each picture is displayed in a slide show, from 3 seconds (default) to 1 hour.
Oct 09, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Jul 31, 2009 | Kodak EasyShare 8" LCD Wi-Fi Digital Photo...
My memory card shows 132 pictures are loaded, but when I put the card in the photoframe, it keeps showing only 4 pictures. I have unplugged and replugged the photframe - but still just the same 4 pictures...
It is possible that they are in a format the picture frame doesnt support. Browse the card with your PC, find the pictures the frame will display and make sure all the other pictures are the same format (ie. jpg, gif, bmp etc).
Jul 24, 2009 | Westinghouse 7" LCD Digital Photo Frame
PANDIGITAL DIGITAL PHOTO FRAME SNOW GLOBE
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Jan 04, 2009 | Kodak EasyShare EX1011 Digital Picture...
Dec 19, 2008 | Sunpak (SDPF-070AW-0US) Digital Picture...
Cameras Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
