Question about GE DWXR483EBCC Electric Dryer
Back panel removal
I have a large ge dryer dwsr405eb1ww. I need to remove rear silver panel to fit it through the door way. I removed all of the screws and it is still not loose. Maybe the front panel needs to be removed?
  • Anonymous Jan 01, 2009
    i have an 15 year old electric dryer # DBXR453ET5WW , the drum seems to be loose and I want to open the back to see if it is the belt . How do i pull the panel off
    Scholar:
  • 111 Answers
Do NOT even try to remove the back panel. It is more complicated than it looks. You would be better off to pull the door jamb off the house... not trying to be funny just serious!
Posted on Dec 18, 2008
Hoover Dryer Model D6792A. Trying to find a user manual or find out how to use the rear vent once its panel is removed
If I remember correctly, there is a venting kit that you purchase which consists of a fitting to go on the back of the dryer and a large diameter hose which you put out the window or door to vent the hot air from the dryer. There used to be another kit which allowed you to connect to a wall outlet which vents directly outside.
Apr 09, 2015 | Dryers
CAN'T GET BACK OFF DRYER TO SEE IF BELT NEEDS CHANGED. DO YOU GET IN THIS MODEL FROM FRONT, BACK OR SIDE?
Access from front. Open door and remove two vertical screws in upper corners of door housing. Lift top slightly and pull forward to remove top. Remove two screws in top corners inside front to remove Front panel.
Nov 15, 2010 | GE DBXR463ED Electric Dryer
How to disassemble a GE DBXR453EV0WW dryer?
Unplug the dryer.
Remove the screws from the control panel top rear.
Lift the control panel aside.
Pull the top lid forward to remove it.
Reach inside the right and left front corners to remove the screws holding the front panel to the cabinet.
Remove the door switch wires and set the front panel aside.
Your model may or may not have 2 screws holding the top lid down located inside the door opening. Open the door,get down on your knees and look up at the door opening for 2 screws.
Jan 03, 2010 | GE Dryers
How is the rear speaker cover removed from a supercab fx4 f150 2004
The rear door panels are not like the front doors ( additional panel on the door panel ), the silver/gray rear speaker panel is part of the rear door panel.
Remove the panels next to the window ( should be spring clips ).
This should expose 3 bolts holding the top of the door panel on.
Next remove the rear window console panel ( spring clips on the side towards the cab, tabs on the side towards the door ).
Behind this should be a bolt.
Next remove the rectangle cover in teh door handle area, there is a bolt behind this.
should be 1 other screw at the bottom of the door panel, by the door sill area ( under the map pocket ).
The door is held on like the front doors, with large plastic hooks, so pick up on the door panel once all the screws are out.
Nov 24, 2009 | 2004 Ford F150
GE Dryer Model DWSR483EA1WW squeaky noises
Un-plug dryer. Remove screws from front panel into dryer top. (just inside the door, at the top of the opening) Swing top up and remove screw near top of front panel on each side. Tilt front panel forward and lift off, set to the side. (leave wires attatched) Pull drum ahead about 4 inches. Do not remove belt. (it's a little tough to get the drum past the sides of the dryer) Remove the old rear drum bearing and replace it. If I remember correctly, it is a part number WE3X37. Replace drum. Check the front drum support slides on the front panel. They should be about 1/8 inch thick. If the rear bearing was squeaking, they may need replacing also. Finish re-assembly, plug back in and test.
Oct 18, 2009 | Dryers
How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Jul 29, 2009 | GE Profile Harmony DPGT750EC Electric...
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Inside dryer silver flaking off
If you need a new drum. Follow the instructions below.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Mar 07, 2009 | LG DLE2514 Electric Dryer
Want to vent dryer from bottom. How do I remove the bottom/side
Unplug the dryer.
Open the dryer door.
Get on your knees and look up.
You will see 2 phillips head screws that must be removed from inside the door cavity.
Remove these screws, then the top of the dryer.
Then remove 2 screws on the right and left inside of the dryer.
Unhook the door wires and remove the front panel.
Feb 21, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
GE PRofile DPSR475EWOWW
Don, the drum on this model rotates on a bearing in back. This is most likely where the sqeeling is comming from. You will have to service this from the front. Should be 2 screws just above the door on each side. Remove them and the top will lift up. Slide the top off forward. Once the top is off, you will see a couple of screws holding the the front panel and door assy. on. One on each side inside front panel. Unplug the door harness and remove the front panel and door. Undo the belt and the drum should pull straight out. Watch out not to get the belt hung on the motor. Now you will see the rear bearing and shaft bracket that the drum rides on. It may need to be replaced or just lubed up real good. Catriver.
Jun 22, 2007 | GE DPSR483EA Electric Dryer
GE DWXR483EBCC Electric Dryer Logo
145 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
