Question about Timex Watches
THE INDIGLO DOES NOT COME ON WHEN THE BUTTON IS PUSHED. THE WATCH CONTINUES TO RUN HOWEVER. THE WATCH WAS A GIFT THAT HAD NO ENCLOSED WARRANTY FOR ME TO FILL OUT/MAIL IN. WHAT CAN YOU DO FOR ME?
  • 2,334 Answers
Many of Timex watches has two separate batteries- one for watch and another for indiglo feature. It looks like you have to replace indiglo battery. Nearest watchmaker will do that for you.
Posted on Dec 18, 2008
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
How do I change time and date on timex indiglo
  • How to Set Dial Indiglo Watches
    • 1Pinch the winding knob on the right side of the watch between your thumb and forefinger.
    • 2 Pull the knob out from the watch slowly until it clicks into the first position.
    • 3Turn the knob to move the hour and minute hand to set the time. Move the knob clockwise to move the settings forward and counterclockwise to move them backwards.
    • 4 Pull the knob out further until it clicks into the second position. In the second position (the one furthest from the face), turn the knob to set the calendar, if your Indiglo has one. Turn the knob clockwise to move the settings forward and counterclockwise to move them backward. Push the knob back in to the watch face when you are done.
    How to Set Digital Indigo Watches
    • 1 Press the button on the lower right side of your Indiglo watch to unlock the mode function of the watch.
    • 2 Press the button on the lower left side to move through the modes. Each time you are in a mode, the digital display will flash. For example, when the time display begins to flash, you are in the correct mode to set the time.
    • 3 Change the time (or date) by pressing the button on the upper right side to advance the numbers or the button on the left side to move the numbers down. When you do this, you will be changing the first set of numbers (the hour or month, for instance); to change the minutes, press the button on the right side of the face until the second set of numbers is flashing and begin the process again.
    • 4 Press the button on the lower left side of the watch to save your settings. The button on the upper left side of the watch is not used in this process--it is the switch to turn on your Indiglo light.
  • Read more : http://www.ehow.com/how_5758168_set-timex-indiglo.html
    Mar 31, 2015 | Timex Indiglo Watches
    I have a timex indiglo, mens watch, A christmas gift, and am having problems setting the day and date. The stem appears to have only one setting, notch
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMES watch manuals. Rate me, please
    Mar 09, 2010 | Timex Indiglo Watch
    Timex T49271 Expedition Indiglo button dead?
    There is no separate battery for the indiglo,maybe indiglo circuit is lose or defected already,just open the watch and check for lose connection.If happen the circuit is tight and still not working then replace the indiglo circuit.
    Hope it may helps you;
    Regards
    VOTIT
    Mar 23, 2009 | Timex Expedition 40141 Wristwatch
    TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
    ANALOG TIME
    Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
    Oct 27, 2008 | Timex Watches
    Acqua Indiglo watch
    Can't understand instructions
    Aug 31, 2008 | Watches
    Indiglo button kills watch function
    I have the same problem with my watch. I replaced the ML-2016 battery myself. (which I found at Walmart) But when I press the iniglo button, it just stops the clock and I have to press the start/split button to get it to resume. No idea how to get the problem resolved
    Aug 19, 2008 | Timex 5J261 Solar Powered Ironman...
    Timex Watch
    While the time is displaying on watch press & hold the set/indiglo or top left button on watch. The seconds should start to flash.
    Press the mode or bottom left button until the hour digits start to flash.
    Press top right or start/stop button to advance the hour. Then press top left or set/indiglo button to exit set mode.
    Mar 09, 2008 | Timex Ironman 30 Lap 53952 Wrist Watch
    Watches Logo
    771 people viewed this question
    Top Timex Watches Experts
    Ansel Alberto
    Ansel Alberto
    Brett Duxbury
    Brett Duxbury
    Vladimir Frolov
    Are you a Timex Watch Expert? Answer questions, earn points and help others
