Question about GE Spacemaker JVM1640SJ Microwave Oven
Does the model JVK142K01 have a turntable?
I bought this microwave (secondhand) and I am wondering if somthing is missing..............a tray? Turntable? it has a metal rack what is that for?
Also how do I get an Owners Manuel for this model?
Nancy
If it has a 3 point spindle in the center then you just need the pyrex glass plate to fit it.
If the floor is flat then you have not a turntable microwave.
Bri.
Posted on Dec 18, 2008
What size turntable plate is needed for ge microwave jes738wj02
The GE JES738WJ02 uses the WB49X10134 turntable tray. According to Amazon, the tray measures ~9 5/8" in diameter. Sears Parts Direct has the parts diagram here: https://www.searspartsdirect.com/model-number/jes738wj02/0432/0123245.html . Amazon describes the tray on the part site: https://www.amazon.com/GE-Microwave-Glass-Turntable-WB49X10134/dp/B00DZPVBVY .
I hope this helps.
Jul 15, 2018 | GE Microwave Ovens
JennAir JMC7000ADW Microwave Oven Turntable not turning
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Dec 17, 2011 | Jenn-Air JMC7000 Microwave Oven
Turntable does not rotate on r24stm model
Good luck.
Walesarumi
Sep 29, 2011 | Microwave Ovens
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
Cookworks microwave oven with grill and convection model cmx60 - I need new glass turntable unable to sourced bought from Argus about three years ago please help.
Microwave turntables are in several sizes
Here are a couple of sources for them. What you have to take note of is the wheel tray also. You may get the right size turntable and not fit the wheel tray. Manufacturer is not as important as the size and tray fitting.
This one seems a bit small at 10 inches but as your microwave is only 800 Watts it may just be the correct one :
http://www.argosspares.co.uk/cgi-bin/product.pl?PID=1162473&brand=Cookworks&model=&part=
You may want to call Argospares 0844 55 70 320
or make an inquiry here: http://www.argosspares.co.uk/cgi-bin/pne.pl?brand=Cookworks
Thanks for choosing FixYa.
Kelly
Sep 14, 2010 | Microwave Ovens
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Which microwave has no turntable?
look at the features the new microwaves have. alot of them have a button to turn the turn table off
Jan 31, 2009 | Microwave Ovens
I Can't Find Microwave Glass Truntable Tray for Jenn-Air
Martin Microwave has one in stock here for $25.99.
I searched for model JVM8000 and this came up.
On a related note, I think that what Smithbrother was talking about is something like a Micro-Go-Round. Here's a related post from my "Ask Mr. Microwave" page.
Q. My turntable is missing or unavailable. What can I do?
A. This sort of arrangement can be a good temporary fix until a suitable replacement tray can be found, or even a permanent solution.
Place a microwave-safe saucer upside-down over your roller ring / turntable support assembly. Then place a microwave-safe plate rightside-up atop the saucer.
Be sure both are centered, checking them frequently to be sure shifting does not occur. Otherwise, a spill of hot material could result. Safety first!
Another option is to check Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware wind-up turntable such as the Micro-Go-Round.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 30, 2008 | Welbilt MR755T Microwave Oven
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Welbilt MR755T Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
77 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
