Question about Westinghouse DPF-1411 Digital Picture Frame
Dpf-1411 locked in slideshow
When I turn the unit on it is locked in slideshow. Pressing the menu or exit buttons has no effect. Also, the slideshow works with a CF card, but freezes when using the internal memory.
  • Greg0729 Dec 24, 2008
    Mine does the same thing. It was a gift and was pre-loaded with pics for me. It worked great for a while, but now locks on one picture and can only be turned off when picture locks.
  • Peaty Apr 29, 2009
    I just got one and it does the same thing. I called their tec support and they told me that the frame does not support Photos that have been edited! I edit all my photos in PhotoShop. To me this seems like BS but I will test the theory. Why would I put a 12MB single unedited photo on a chip when I can put a very small, properly edited one on a chip that will hold many more photos? Nowhere was this mentioned on the site I got the frame from but Westinghouse said it's user manual and up to the place that sells it to put that info up.
To fix the freezing problem, all you have to do is change the file names to basic numbers. If you have long file names, it causes the pictures to freeze up. Change the names, and the problem stops!
Posted on Dec 31, 2008
Things I have learned after messing with 3 different Westinghouse DPFs (1 -14" & 2 - 10").
1. Just tap the buttons. Exit first and then Menu or one of the other functions. Holding them down too long seems to nullify the functions. Only the Power button needs to be held down for a second or two to turn the device on or off.
2. Use a USB to mini-USB cable to access the internal memory. Expect flakiness when you plug in the cable. Sometimes it will warn the USB 2 device is plugged into USB1 port. Ignore this and just look for a string of removable drive letters to show up in My Computer window. The one named FLASH Drive is the internal memory.
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing you lock ups.
4. I have had good succcess the xD memory cards from 16MB to 1GB.
5. I have not seen any orblems with edited photos - just be sure they are named with .jog extension and not .jpeg. - go figure?
Hope this helps...
Posted on May 04, 2009
  • pcalmes May 04, 2009
    My typing is not so good. I meant to say "problems" - not orplems and ".jpg" for the workable file extension.
    Sorry,
    Paul
In my experience freezing had nothing to do with file naming (length or casing), but rather with the number of pictures on your media. I tested with 1GB and 2GB CF cards, and noticed that when you go to "Photo", it would display the pages counter only up to 667 pages (6 pictures each). Last page would have 2 blank spots. It hinted that there is an internal limitation of 4000 pics. By trial and error I found that "Slide Show" is capable of handling somewhere in the area of 3700 pictures max.
Editing puctures in Photoshop is possible, but (also by trial and error) you have to avoid "progressive" when you are saving in jpg format.
Tech support is kind of useless. They said to me that there is no limit on number of pictures, but since I "informed" them of what they have done as manufacturers, apparently there is in fact the limit of 4000.
Posted on Dec 28, 2009
  • 3 Answers
I guess your unit has the function, that displaying the slideshow automaticlly when turning on with the CF card inserted.
I think it can be tried that turn it on, then insert CF card, enter the menu to see if it can be read.
Some digital frame solution only support that to display pictures with music as backgroud. The music is necessary. So it is better to have pictures and music in the internal memory at the same time.
Hope these could help.
Any question, I wil try my best to help.
Posted on Dec 18, 2008
I have a Westinghouse DPF-1021 and experienced a similar problem. I have 1,800 pictures on a SD card and anywhere from 2 to 8 minutes into slideshow the slideshow locks up and the unit has to be turned off and on again to recover.
After trying everything suggested here, and a lot of frustration, I found a fix! Using a freeware application called "IrfanView for Windows XP", I was able to resize all of the images in a batch process so that no image had a dimension larger than 680 pixels. I believe that works by effectively limiting the filesize for each photo to around 60KB. I don't notice any degradation in quality on the DPF-1021.
It took about 10 minutes to run the batch process and was very easy to do using the IrfanView software. While I was running the batch process, I also renamed all the files in a numerical sequence during the same batch process. This was all pretty easy using the software and only took me a few minutes to figure out. The batch process is in the file menu of the application. Press "advanced" to perform the resize.
Posted on Jul 19, 2010
How do I exit the service menu on this TV?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Jul 14, 2015 | Televison & Video
Westinghouse dpf 1411 shuts off after 2 minutes, wont stay on
Check your settings, maybe you have an auto-off feature turned on. If this is not the case, seek professional help, it's probably a software problem.
Apr 07, 2010 | Westinghouse DPF-1411 Digital Picture...
Effects doesnt scroll?
You MAY have to exit the mode first to change it... Try pressing the sync-lock button to exit the mode before changing.
The D2 PROBABLY means "delay 2"... although the documentation is really poor... One has to read between the lines...
Jan 17, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Westinghouse dpf 1411 wont turn on power block
I would recommend contacting Westinghouse customer service team at 1800-701-0680 for further assistance in getting this frame replaced.
Dec 31, 2009 | Westinghouse DPF-1411 Digital Picture...
I have a DPF-1411. It will run thru one cycle and then freeze on last picture. Turn off-on and does same thing.
There should be a repeat setting in the menu. It is only playing once through and stopping.
Eric
Jul 02, 2009 | Westinghouse DPF-0702 Digital Picture...
Westinghouse DPF-01411 Digital Photo Frame
3. I reformat the internal memory (FAT32 seems to work fine) and this gets rid of the troublesome canned pictures that may be causing your lock ups.
5. I have not seen any prblems with edited photos or long file names - just be sure they are named with .jpg extension and not .jpeg. - go figure?
Hope this helps...
Mar 30, 2009 | Westinghouse DPF-1411 Digital Picture...
Screen menu displays locked & unlocked
possible faulty VGA Controller board.
Dec 03, 2007 | Gateway FPD2275W LCD Monitor
Turn off child lock
To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
  1. Turn on your TV.
  2. On the remote, press the Menu button. The Set-Up Menu appears.
  3. Scroll to the Key Lock function and set function to Off.
  4. Press the Exit button to exit.
Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
Oct 02, 2007 | Televison & Video
Cannot down TV Schedule
1. Press Menu on the remote. 2. Choose Setup from the menu. 3. Scroll to Connect to ReplayTV Service Now. 4. If you don't have this option try this. For ReplayTVs running older software: 1. First, exit any menus you're currently in. 2. Press "2-4-3" on the remote followed quickly by pressing the "Zones" button - this will launch an informational screen, with like a 1-Exit, 2-Clear the Channel, etc. 3. Select #7, 'Net Connect' from the menu. (#4 on ReplayTV 2000 or 3000 series). A message at the bottom of the tv screen will indicate a successful connection. If you are unable to force a connection using this method, you may need to reboot your unit. This is done by pressing and holding the "Power" button on the front of the unit for 10 seconds. (Note: When you hear the fan in the rear of the unit turn off, your unit is rebooting.) Now repeat the previous instructions to force a connection. This is all found on the support site: http://www.digitalnetworksna.com/support/replaytv/document.asp?docID=87
Sep 22, 2007 | Panasonic PV-HS2000 Showstopper 30-Hours...
Toshiba PDR M700 Slideshow
Have you tried pressing the 'down' button?
Good luck.
Aug 12, 2007 | Toshiba PDR-M700 Digital Camera
Westinghouse DPF-1411 Digital Picture Frame Logo
972 people viewed this question
Top Westinghouse Photography Experts
teddyboy
Tom Chichester
Tom Lahart
Level 1 Expert
Are you a Westinghouse Photography Expert? Answer questions, earn points and help others
