Question about AEG 24 in. Favorit 40850 Free-standing Dishwasher
Aeg favourit- water not heating up
I've noticed the water in my machine not heating up at all and the dishes are not getting clean- also the tablet does not disolve. do i need a new one or will i be able to get it fixed and will it be expensive?- only had it 2 years. thanks.
  • 1 more comment
  • Anonymous Sep 03, 2008
    Thankyou Bulgaria,my aeg 40850 had the black burn marks on the circuit board ive re soldered on one of the relay pins now all working.My machine is only 2.5years old.i hope people look at your advice it would be sad for people to scrap these machines (which i find superb) for such an easy repair.
  • Anonymous Dec 01, 2008
    aeg Favorit 88070i I have this same problem the water does not appear to be warming up . The tablet is not dissolving and the dishes are not clean
  • fychan Feb 07, 2009
    Exactly the same problem - the dishwasher water was not heating up, the items weren't drying, the tablets weren't dissolving...
    Bulgaria's fix worked wonders. Undid the screws on the door, removed panel and top plastic option. Disconnected power switch cable to give more room to work in. Found the control box Bulgaria talked about - it's the white plastic box that has all the buttons on the right hand side, and the counter display in it. Pops out of its holding clips easily - then opens easily once you undo the 4 holding clips (2 each side).
    Numbering the wire connectors before disconnecting is highly recommended!! SOOO glad I did when I came back to reseating them. #6 (numbering from left to right when looking down on opened circuit board) I also made sure I noted that it needed to be sat to the left of the long connector option. Removing these wire connectors was a bit fiddly because of the top of the top of the box having clips holding the sockets in place, but a bit of manoeuvring helped free them.
    Lifting out circuit board, there was a BIG scorch mark on the inside of the plastic case, and above where that was, the circuit board was also scorched and the wire at the centre of the mark had lost all its connecting solder. Re-soldering the wire onto the connector and putting everything back solved the problem.
    Would never have known what to do without Bulgaria's advice - although not being an electrician or mechanically minded at all (last time I used the soldering iron was about 12 years ago - and that was its first use!) I was guessing what he meant half the time. Hence my less techy description of my fix ;)
    This is the 6th or 7th time I've had to fix the dishwasher now tho (the top hose keeps coming loose and the power switch has stopped holding itself in the 'on' position several times), I'm never going to buy AEG again (although, it helps that all these problems I have been able to solve myself!)
AEG Favorit 40850 Problem : Water not heating. Solution : Checking the heater Access to the heater (tube type) is via the small rear panel. Remove two star screws, and pull the sides out SLIGHTLY to release the panel. The electrical contacts of the heater are to the inside so are not visible yet. I removed the left hose (hose compression clip) and the earth connection on the bottom of the heater. This allowed me to twist the heater round and see the electrical connector. I removed this, and measured the resistance of the heater. It was 28Ω, from reading various forums, this seems to be of the correct order, therefore the heater is ok. I put everything back together, remembering the earth connection on the bottom, and turned to the front of the machine Checking the Relay : Again from reading around there is a relay in the supply chain to the heater, described as ?in the door?. I opened the door and removed the crosshead screws. This released the front panel from the inner metal part. The control switches and the mains switch are held in with clips, easily removed, I guess you could leave the mains switch connected to the front panel, but I removed it so that the skin would not be pulling on any wires. I then wrote (with an indelible pen) a number on all the connectors to the control box, noting that one of them has to be fitted at one particular end of the unit connector, as it could fit in more than one position. With the control unit removed the next step was to open it up. The control unit is clipped together with four clips, just press them in and it opens. At this point I should say that there are proper electronics inside this box, so some sort of static protection should be observed! Ground yourself before working inside the unit, touching something metal connected to ground should to the trick (radiator, but not the painted part!), and do not touch any of the components on the board, or the connections. Be careful of the flexible connection between the two boards, do not bend it any more than necessary. The relay mentioned above is in the bottom left of the board in my extremely bad picture. Unclip the main board, and have a look around where the relay is on the other side. One of my pins was charred, and on closer inspection was not actually making contact!! Looks like it was a bad / high impedance joint that was getting hot, and finally melted the solder causing the open circuit that made the heater not work. With a soldering iron I reflowed the solder (adding more as necessary) to make the connection between the relay pin and PCB good. This was the only visible problem, so I reassembled everything (reverse order of disassembly, Haynes is a wonderful manual!!!) and tried the machine. IT WORKED!!! The whole process took probable less than an hour, and saved the cost of a repair man, and a new control unit (I don?t think anybody fixes things like this on a commercial bases any more, easier for them to just replace the unit!! This is what I did to fix my water not heating problem, I am experienced with electrical and electronic components, so if you choose to follow my story please be careful, it can save a few pounds, but it?s not worth risking your life if you really don?t know what you are doing. For interest, the relay is a NAIS device, numbers on the top are JS1-B-12V-F-H111, and AJS1311F MO1. My relay was working so I didn?t need to look for a replacement, but they should be fairly easy to find if yours is broken. Being an electromechanical device this is probably the most unreliable component in the heater chain, although if the rest of the circuit is designed correctly should last for years, if not decades. (I have seen relays used in gas boilers that had no suppression, and therefore burnt themselves out within 3-4 years, but I don?t think that is the case here)
Posted on Sep 15, 2007
  • Eirik Heggland Sep 24, 2012
    Big thanks to Bulgaria. I discovered the same fault in my dishwasher too. Saved me alot of time and money.
  • Richard Avery
    Richard Avery Apr 11, 2014
    I found that the relay itself was blown.
I had the same problem, water had not been heated..
I went through the Bulgaria´s hints. I am very grateful Bulgaria´s good job, many thanks to him!
I omit checking resistance (functionality) of heater itself because of my believe in problem location in control unit - to avoid a need of washer manipulation itself.
I would like to add some hints.
First. The removal of front two parts door cover is three-four hands job. Top part is with little tingue fixed to bottom part. That´s why you should only loose bottom part screws first, then free top part from frame completely and then fix bottom part again temporarily. That´s time to click switch and control unit plast boxes off from top cover part. Than, you free cables more with removal of bottom part cover. Styrofoam piece under bottom part could be removed or fixed with adhesive tape.
Second. To free control box you should pull the connectors out. When I grounded myself (static charge) I opened control unit box first and I pressed connectors from their possitions by fingers with caution. I decided this way to avoid risk of breaking connectors and/or wrench cables in case I pulled them.
Third. Eye inspection to printed circuit was the textbook one, Bulgaria had mentioned about. There was charred joint there. It was impossible to resolder relay pin to charred joint, every next try to do it would go to next unproper connection (drop of soldering tin instead of small „roof“) and degradation of printed circuit. The solution was short fine wire, one side soldered to relay pin itself, second side soldered to joint before charred field, the relay contact is surrounded by. This is only other, more safe way of reconnection, Bulgaria said „I reflowed the solder (adding more as necessary)“.
Fourth. Before you reconnect the connectors to control unit, you can clean printed circuit contact fields with soft school eraser for better contact. Eraser movement in direction perpendicular to edge only!
Again, many many thanks to Bulgaria´s research.
Posted on Dec 01, 2008
Viva la bulgaria. AEG 40850 working again !!! Thank you very much. I went directly to the relay, because my dishwasher didn't dry the dishes as well and voila, some 500+ EUR is saved for the moment. Thanx a lot bulgaria.
Posted on May 30, 2008
Just wanted to say a big thank you to Bulgaria. I had the very same heating problem with my AEG dishwasher and had replaced the heating element with no effect. I then followed Bulgaria's advise and bingo! the thing now works! I would make a small suggestion though. My soldering skill was very limited and it sems to be critical that the soldered area is kept neat and you should ensure that you don't use to much to repair the connection
Once again Bulgaria-many many thanks.
Posted on Apr 16, 2008
Check the relay located on the pcb situated inside the door of the dishwasher, this may be defective or have adry joint on the underside of the board. also check the water heater itself, this is a tubular flow through heater
Posted on May 10, 2007
This fixed my problem also. Although there were no black burn marks on the plastichousing there ewas a wire poking through the PCB with no apparent solder. Soldering iron cost me £14, inc. solder. I'm amazed, as is the Mrs.
Thank you Bulgaria!
Posted on Aug 26, 2009
This looks to have solved the problem. Mrs thought I was crazy as I purchased a soldering iron, very easy fix. Thanks to all who posted!
Posted on Aug 24, 2009
I had a similar fault on my F54850 and traced it bach to solder failure on the BACK of the control panel.
Dry joint and black burn marks round it - a very obvious fault.
...should have looked there first as it was much easier than getting to the heating element on this slimline dishwasher
Posted on Aug 06, 2008
The solution from Bulgaria was the best!
I had the same heating problem. And yes one of the pins of the relay was completely burned...
After some soldering it did not worked. Than I directly conect two lines from relay during working of washmachine and ...
ant it start to work.
It is great thanks to all and thanks to internet.
See U in future
JoN
www.ateliersuzanne.cz
thanks for the input.
Posted on Mar 07, 2008
After some soldering it worked like a charm again.
Eddy
Posted on Feb 12, 2008
    President:
  • 1,462 Answers
Difficult to diagnose without mor detail. however, is the element visible inside the cabinet? if not the element is in the base and is a cylindrical type. these often go open circuit
Posted on Mar 29, 2007
AEG FAVOURIT 675 no water coming threw plastic tube on top of washer. How can I fix and check this problem.
Replace your water pump ... probably working but impeller is too worn! Good Luck! Handy Henry
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Feb 19, 2017 | AEG Washing Machines
No hot water
If there is no hot water it could be (a) the heating element has gone or (b) the switching system has failrd somewhere - probably a relay or (c) the circuit card has gone (expensive)
Mar 23, 2014 | AEG 18 in. Favorit 54750Vi Slim-Line...
Aeg l12510vi
get yourself an old tooth brush ??
take out soap dish
and clean the inside of the soap dish holder
Jan 29, 2014 | Washing Machines
I went to take out my dishes out of the dishwasher this morning and the tablet was sitting at the bottom of the machine half disolved and most of my dishes weren't washed properly. What is the problem?
1. Check that water enters dishwasher.
2. Check that water is heated,tablet door will then open, this allows the propellor to shoot hot water at tablet to dissolve.
Apr 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
Hi. The dishwasher appears not to heat up all the time. The soap drawer does open, but open the tablet does not disolve. This leaves the dshwasher very cloudy and often still dirty. I have also noticed...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 28, 2011 | AEG 24 in. Favorit 40850 Free-standing...
Tablet not fully dissolving. dishes not clean after wash.
The water is not hot enough. It may be pausing to heat the water and when you open the door it resets and starts again. Check the electric element at the bottom that heats the water to see if it is burnt out.
Jul 22, 2009 | Dishwashers
Not cleaning properly
You could be using the dishwasher at a higher temperature than the biological agents in the tablets can handle, and so become denatured and can't clean your dishes properly. I have had this problem a little while ago and found that using the "eco" setting (should heat the water to around 30c and has the added bonus of using less water) works well and makes sure that all of the dishes are clean.
It could also be a problem with the release system, where the door the holds the tablet can't release it on time and so the tablet does not dissove. Have a check to see if anything is stopping the door opening and see if there is anything you can do to make it release on time.
Hope this helps,
BurntLime
Jan 05, 2009 | Dishwashers
Having problems with AEG dishwasher-tablet not dissolving..
open the door when in cycle and check both spray arms are rotating. you will get a bit of water out but not a lot. if arms not rotating, then this is caused usually by rubbish in the spray arm jets so clean them. also check water is being heated
Aug 05, 2008 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG 24 in. Favorit 40850 Free-standing Dishwasher Logo
6,623 people viewed this question
Top AEG Dishwashers Experts
Paul Carew
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
