Question about Konica Minolta magicolor 2430 DL Laser Printer
Magicolor 2430DL shows no cartridges installed. When I try to change cartridge message shows ERROR line 2474? Please advise? same problem error line 2474
  • zorq Dec 19, 2008
    I have the same problem with Konica Minolta Magicolor 2430DL. I removed all the cartridges in order to replace them. When I try to install a cartridge through MENU/ENGINE/REPLACE TONER/black-cyan-magenta-yellow-all I get the message "Err: Line 2474" and the printer stalls. Is this a hardware or software problem ? I have firmware 2.13. Is it possible to downgrade ? Please help.
    Problem Solver:
  • 9 Answers
Http://www.fixya.com/support/t474251-minolta_2430dl_x_toner_not_installed
Posted on Dec 21, 2008
Toner not installed message
Had similar hassle. Just take each cartridge and install and reinstall each a bunch of times - no need to be gentle. Often the cartridge sensor contacts get oxidized. By opening and closing them repeatedly you can clean the contacts and restore proper operation.
Aug 22, 2015 | Konica Minolta magicolor 2430DL
My Magicolor 2430dl: error: line 2408
using 3rd party or oem cartridge?? use Oem and or replace the image unit with a new one.
Nov 06, 2009 | Minolta 2430DL Color Laser Printer
I have replace the yellow colour and ever since the printer comes up with a error saying no toner
this is a very annoying error message
Konica Minolta Magicolor 2400/2500 series printer "X cartridge not installed" One of the most frustrating features of the Magicolor 2400/2500 series of printers is the very annoying X Cartridge not installed message
This error message can occur at any time with both original cartridges and or refilled cartridges. It is caused by either toner / paper dust covering either the chip on the toner cartridge or dust covering the chip sensor inside the printer. It can also be caused by a faulty chip reader inside the printer.
The printer uses a carousel to rotate the toner cartridges. Dust and toner can easily spill as the cartridges rotate. The error can appear at any time but seems to be most annoying after a paper jam or other error. It is also important to make sure that the cartridges themselves are clear of toner dust. Pay particulair attention to any copper contacts on the cartridge.
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Nov 03, 2009 | Konica Minolta Magicolor 2450 Printer
How to rotate toner cartridges to replace K
Well on my 2430DL the release for the toner carousel is definitely not where komguy says it is. Open the top cover and on top of the printer case on the right hand side you will see a hole now exposed by opening the top cover. You think at first it is where the top cover latches into as it is more or less identically placed (but on the right) to where the top cover latch does latch into (on the left hand side).
Stick a pen or something into this hole and you will feel a some spring resistance - push down and the carousel will rotate until you can get access to each toner cartridge in turn.
Note that you can do this via the replace toner function on the LCD menu but for me I get the dreaded Err: Line 2474 error when I try to invoke the replace toner function and so I had to find a manual way of rotating the carousel.
Andy
Oct 30, 2009 | Konica Minolta magicolor 2430 DL Laser...
Printer will not prine
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Konica Minolta magicolor 2430 DL Laser...
KONICA MINOLTA 2430DL
do trust the computer replace the each unit and use only Konica Minolta units third party can give bad problems
Apr 15, 2017 | Konica Minolta Office Equipment & Supplies
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
How to reset Black Toner Empty Message on 2430Dl
There are many problems like that and its not recommended to change toner from one printer to another.
but you should try: put the old toner (emty) in again, then turn off the printer, change toner and turn on printer again.
if thats not helping, then maybe you have a old FW so you can try to update the firmware.
Jan 13, 2008 | Konica Minolta magicolor 2430 DL Laser...
Streaks on printed page
You need to clean the printer. See your manual for instructions. It is probably dust on the laser lens
Jun 03, 2007 | Konica Minolta magicolor 2400 Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
1,030 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
