Question about Microsoft Xbox 360 Console
3 flashing red lights
When I turn on my Xbox 360 3 flashing red lights appear and it won't let me play it.
  • 57 Answers
Im sorry to hear and tell you this...
You must know that that is a issue called the Red Ring of Death and is only fixed getting it sent into Microsoft. If it is no more than 2 to 3 years old you will be able to have it fixed for free.
Posted on Dec 18, 2008
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
2 red lights
Your xbox is overheating.
1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot. 2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating. 3. If the two lights continue to flash after trying the above steps, you'll need to contact Xbox Customer Support.
Jul 13, 2009 | Microsoft Xbox 360 Console
2 red flashing lights
The Xbox console is overheated.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
2 red lights
This problem may occur when the Xbox console is too hot or is overheating. The flashing lights mean that the internal temperature of your Xbox 360 console has exceeded acceptable temperature limits. Let your Xbox 360 console cool. You may have to wait several hours for your Xbox 360 console to cool enough. Don't turn on your Xbox 360 console when the console is hot.Verify that your Xbox 360 console has enough ventilation and that the fans are operating. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
Microsoft can be contacted by finding the number listed on the back of your video game booklets.
Good Luck to you and Happy Gaming.
Source:
http://support.microsoft.com/kb/907533
Oct 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
