Question about Cameras
Tape stuck in Digital 8 (Moisture Condensation?)
I own a Sony Digital 8 Handycam.My tape is stuck and won't release. I also found out that it has a problem with moisture condensation, at least according to the error code and warning beeps. I will leave the door open and wait a few hours to see if that helps. What are your suggestions? Thanks you, sincerely visualtea.
  • 78 Answers
I had same prob with my digital high 8 sony also.
dont panick!!,just get it warm so it gets dry!!
(i only had the prob once in 10 years!)
Posted on Dec 18, 2008
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Flashing drop sign, will not load a tape
Condensation has detected by your camera, leave it on for few hours until moisture dries gone. Hope this helps
Mar 08, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Feb 26, 2009 | Sony Handycam DCR-TRV250 Digital Camcorder
Hi8 Tape Will Eject but will not forward/record/rewind,
a problem with an electro mechanical mode-select switch there could be a timing problem arised by mechanical problems on contacts inside (an old video recorder problem between the seventies and nineties ) all equipments where tapes or cassettes are used.
A service manual for timing should be neccesary
Sony CCD TRV16 Hi8 Handycam Camcorder Service Manual Page 13
Apr 01, 2017 | Sony Hi8 Hi-8 Tape
Sony TRV120 Won't load tape C21:00 code
From the user manual ...
Under self diagnosis display
C21:00
Moisture condensation has occurred.
Remove the cassette and leave your camcorder for at least 1 hour to acclimatize. (p117)
On p117
If your camcorder is brought directly from a cold to a warm place, moisture may condense inside your camcorder, on the surface of the tape, or on the lens. In this condition, the tape may stick to the head drum and be damaged or your camcorder may not operate correctly. If there is moisture inside your camcorder, the beep sounds and the [picture of water drip] indicator flashes. When the [end tape icon] indicator flashes at the same time, the cassette is inserted in your camcorder. If moisture condenses on the lens, the indicator will not appear.
If moisture condensation occurred
None of the functions except cassette ejection will work. Eject the cassette, turn off your camcorder, and leave it for about 1 hour with the cassette compartment open. Your camcorder can be used again if the [water drip] indicator does not appear when the power is turned on again.
Note on moisture condensation
Moisture may condense when you bring your camcorder from a cold place into a warm place (or vice-versa) or when you use your camcorder in a hot place as follows:
- You bring your camcorder from a ski slope into a place warmed up by a heating device.
- You bring your camcorder from an air-conditioned car or room into a hot place outside.
- You use your camcorder after a squall or a shower.
- You use your camcorder in a high temperature and humidity place.
How to prevent moisture condensation
when you bring your camcorder from a cold place into a warm place, put your camcorder in a plastic bag and tightly seal it. Remove the bag when the air temperature inside the plastic bag has reached the surrounding temperature (after about 1 hour).
Dec 06, 2008 | Sony Handycam DCR-TRV120BT Digital...
Sony hi 8 tape stuck
Take out the battery and put it back in. It should openthen.
Oct 14, 2008 | Sony Handycam CCD-TRV87 Camcorder
Reinsert tape (ah)
its not condensation, perhaps on the tape, but not in the camcorder. i have the same damn problem and its really pissing me off. im a truck driver and when i see something i want the thing to work!! anyways, ive tried to take the tape out and wind the actual tape in the tape tighter by spinning the ummm, things haha. if you take out the tape thats not working and put in a new tape it works. also, theres no condensation in my big rig, its hotter then a barn in here and i have a nice leather case for my cam corder. so this problem is a pure design flaw and im pissed. peace out.
Aug 18, 2006 | Sony Handycam DCR-TRV280 Digital Camcorder
Cameras Logo
128 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
