Question about Water Heaters
Cant get my waterheater lighter to reignite
For some reason the shower was cold and I went down to the water heater to see if the pilot was still lit.
It appears it is not and the water heater is quiet.
I tried to reset and follow the lighting instructions, but still no luck.
Is there a way to try a match as the button ignitormay not be working?
  • wildsidegall Dec 18, 2008
    thank you ...I'll give it a shot..
  • rolltider743 Feb 26, 2009
    I have the same problem mine starts with FGN model number. I had my gas serviceman come out and he called his boss b/c he said thermocouple was bad but all he had was right handed threaded t couple and mine is left handed. The boss told him there was a recall on this model and to call whirpool and they would ship you out the whole new burning assembly. I just called and mine should be in Saturday evening. Hope this helps!
I have a whirlpool water heater; pilot and burner are off, i am able to turn the pilot on and will stay on as long as the heater is cold and the burner is off; when i turn on the burner, the heater will run for about 15 min and then pilot and burner will go off,after that happens the pilot will light up but will not stay on, then i have to wait until pilot and burner are off again to repeat the process.
Posted on Jan 09, 2009
  • 107 Answers
Sounds like the gas valve has failed. The gas valve can be replaced. It will unscrew out of the tank. Shut the water supply to the tank off and get the new gas ready to screw in. Take out the old and screw in the new, you will onlt lose about a cup or two of water if you are quick enough. Otherwise drain the tank down if you must. If you are going to replace the gas valve I would also replace the thermocoupler.
Posted on Dec 18, 2008
  • Paul Robbins Dec 18, 2008
    Sorry missed the last question.
    If you are pushing ignitor and do not see the spark then you are correct it has failed. You can light it with a candle lighter. Turn switch to pilot and hold down.
We have had major blackouts does my bosch highflow 21e need to be reignited or automatic....how long should it be until I get hot water
you have to reignite it yourself turn dial to pilot and press down the light with either the internal igniter or a long match when lit then you turn dial to the ON position .
Apr 25, 2015 | Bosch Water Heaters
Waterheater does not keep water hot when you get in the shower first thing in the morning you have to turn on only the hot water or the water is cold
1) Unknown water heater type, brand and model.
Check for crossover first to eliminate plumbing problem.
http://waterheatertimer.org/Crossover.html
2) Add comment with more information about water heater for possible assistance, and give type, approximate age etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 21, 2013 | Water Heaters
A.O. Smith ProMax Plus GVR 50 101 Safety Question
You need to inspect and clean the air intake located on bottom of unit. Get more fresh air to the water heater and see if problem continues.
http://waterheatertimer.org/images/Flame-trap-inspection-325.jpg
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
Instructions for lighting the unit are located on front of water heater.
Other possible causes include: bad gas control valve, dirty combustion parts, reverse draft down the stack (caused by wind and opening door inside closed utility room), low gas pressure, air in gas line, etc.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Propane gas is heavier than air. So if you have a gas leak, then smell close to floor. Leave house immediately if you smell gas. Install a gas detector close to floor level near gas appliances.
Most water heaters today are extremely safe, because we experimented on prior generations of people, who then passed along their experience.
Aug 12, 2012 | Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot wont stay lit on waterheater. I replaced Thermocouple and that did not fix it. It will stay lit on vacation setting.
Most gas water heater problems can be fixed with yearly service that cleans burner and burner parts, checks gas pressure and bleeds air out of gas line, cleans air intake, and checks for venting and air intake problems.
Open following links for resources:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
Jul 27, 2011 | Water Heaters
Pilot light will not stay lit on my gas hot water heater
either a bad thermocouple, or the unit is bad. you don't mention a make or model so I can't look up the gas valve and parts for you, But if you reply to this, I will do a search for you
Jul 06, 2011 | Whirlpool Water Heaters
I turn oof my hot water to do some fix at the shower, and now i dont have hot water, i know the problem is in the heater, but what?
Are you sure the pilot is still lit or that it stayed lit if you tried to relight it?
If the pilot is on check to be certain no one turned the temp setting way down.
Finally, check the cold water valve at the inlet to the tank. Is it open? Does the knob spin very freely possibly indicating the valve stem is broken?
If you check those things and nothing cures it, please reply to this with a description of what you find.
Dec 17, 2009 | Water Heaters
Bosch Water Wizard 600 pilot light keeps going out
You need a new thermocouple. Its the little stick like thing that the flame heats up to tell gas valve to open.
Jun 15, 2009 | Bosch Water Heaters
Water heater has hot water in it but cold water is still flowing
Nothing wrong with waterheater. Did you perhaps reverse hot/supply lines on new shut off valves?? try reversing lines. Maybe
Please rate. Thanks jj505
Mar 28, 2009 | Whirlpool Water Heaters
Potterton FF80 boiler, pilot light has gone out how do we relight
if you can see where the pilot is you can turn the gas in the on position and use a long candle lighter and manualy light it but be careful doinng so
Nov 12, 2008 | Stiebel Eltron DHC Instant Tankless...
Water Heaters Logo
685 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
