Question about GE JKP27 Electric Double Oven
GE oven Model JKP27
F8 indicates control panel usually needs replacement. Have cycled power - no help.
Any way to trouble shoot this unit?
Thanks a bunch!
  • jl_norton Mar 26, 2009
    Power flashed on and off a couple times last night and when it was all done only an orange colored static "F8" appears on the lcd panel. Turned breaker on and off renders same results.
  • 145 Answers
SOURCE: Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Posted on Apr 18, 2008
  • 8 Answers
SOURCE: F7 error message on GE oven
Send an e-mail to Charlie at for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem so far.
My oven is also a JT950 and the builder installed it in our home back in 2000. Our F7 issue started about 2 years ago. For a few months, "clearing" the panel and/or shutting the oven off at the breaker panel would temporarily solve the problem. About 1 1/2 year ago, however, the F7 would come on and continually beep. A repairman looked at the oven and replaced the control panel at a cost of $600 (ugh...). That solved the problem until a month ago when the F7 continuous beeping began again. There was no way I was going to pay another $600. for "temporary" repair and I was thinking of replacing the oven. Luckily, I came across the above-mentioned fix-it information and took a chance by following the simple instructions provided.
Posted on Jul 27, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
Posted on Mar 28, 2009
  • 5 Answers
SOURCE: ge extra large self cleaning oven xl44 mode jgbp28ded1wh
Check to see if the ignitor glows in the oven. If it does not come on or comes on very dim, you have a bad ignitor. It is usually a bad ignitor. They are very simple to replace. Just unplug the oven first. Then take off the bottom of the oven floor inside the oven to access the ignitor. the ignitor has 2 wires going to a plug, just unplug the plug and remove the mounting screws. Take your ignitor to a local appliance store to get a replacement. There are 2 models of ignitors so bring the old one with you to make sure you get the right one. Good luck..
Posted on Apr 01, 2009
  • 1922 Answers
SOURCE: I need an oven element for a GE JKP27...Can you
"Appliance Parts Pro's" web site they'll have one and their prices are REASONABLE and shipping is FAST too
Posted on Jul 25, 2009
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
I have a GE JKP45 Double Wall Oven. The upper oven stopped working after the self-clean cycle completed. There are no errors showing on the control panel. The lock circuit thermal switch located behind...
the bimetals you checked, did you remove them from the circuit before checking? if all of the thermals, not going to a fan are closed, then you have either a control problem or an element. after self cleaning usually the HIGH LIMIT thermal opens, and is a simple replacement. but if all are good then you need to look deeper. there should be an tech sheet in the control top or control panel area that can help you trouble shoot.
Feb 04, 2012 | Ovens
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
Sep 28, 2011 | GE JKP27 Electric Double Oven
GE model # jkp27 error code F1 what should I do?
Hi ssantillo,
Usually F1 error code means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope this helps.
Thank you for using FixYa.
Apr 27, 2011 | GE JKP27 Electric Double Oven
The F7 alert keeps flashing/beeping on my JKP27 GE electric double oven even after clearing it or cutting the power to the oven for a period of time. Any suggestions? Thanks!
Ya either have a stuck keypad or a bad oven control. To see what it is you push the clear/off pad, disconnect the ribbon from the control and wait 32 seconds, to see if the if the F-7 code occurs again, If it don't then bad keypad, if it does then bad control.
Jan 28, 2010 | GE JKP28 Electric Double Oven
Bubbles on control panel overlay
If the overlay isn't a protective foil that easily peals off, the hair dryer would only serve to distort it, I don't believe it will cause it to shrink to fit. If it was applied with a 'self-stick' backing, you may be able to puncture the bubbles and press it back down with a hot rag.
Sep 15, 2009 | GE JKP27 Electric Double Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
F3 usually means an open oven sensor. Turn off the power. Disconnect the sensor harness from the control. Measure the resistance with an ohmmeter. The resistance should be approximately 1080 ohms at room temperature. If it is greater than 2900 ohms it needs to be replaced. Make certain you disconnect the power before messing with the controls. Look for damaged harness terminals if the sensor checks out to be OK. There should be a set of service instructions in the top of the oven that will help you identify the specific connections for the sensor.
May 01, 2007 | GE JKP27 Electric Double Oven
Ovens Logo
74 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
