Question about Kenmore Washing Machines
Error code f24
Have kenmore front loading washer model #11047561601 serial #hlu4760364 and i keep getting a error code f24 and the washer stops .
  • 2 more comments
  • brucehrl Dec 18, 2008
    does anybody know where the sensor is located
  • Maverick101 Apr 12, 2009
    Our cleaning staff used the washer. When I returned home the washer light was indicating the F-024 error. When I tried restarting the machine in various modes, I would still get the F-24 signal when I pressed the Start button. I also tried unplugging, resetting in the rinse mode, switting off the power by switch and by circuit breaker.
  • vandamme859 Apr 16, 2009
    is the sensor easy to get to? or does the whole top have to come off
  • Anonymous Mar 18, 2014
    fix f24 code he2t kenmore washer front loader
  • 8,197 Answers
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
  • Jyackle5
    Jyackle5 Dec 18, 2008
    The sencer is behind where the water input is.
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ... > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...'s+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ... > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
Error code f28 on Kenmore HE2t model #11047561601
my washer modle 970-C41062-00 my iner bearing it boken i take a part but i try to find bearing kit parts number .I need parts number.kit
If Do you kno it. thank you.
Sep 16, 2013 | Kenmore HE2 Plus Front Load Washer
Kenmore he2 front door panel bolts 11047561601
The HE machines use what are called torque bits, and you'll need one to remove them because there isn't a socket that fits them. I want to say its a t-25 or t-27
May 28, 2012 | Kenmore HE2 Plus Front Load Washer
Washer stopped working and flashes f-24
"F24" is a NTC Heat Sensor error. The following link explains:
This error code may be attributed to a heat sensor that has come loose and may not necessarily be an indication of a failed component. If you require additional troubleshooting advice, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 21, 2011 | Kenmore HE2 Plus Front Load Washer
Flashing F24
All Kenmore appliances are built by other manufacturers, therefore you will need to provide your complete model number in order for us to determine who made your washer. Once we determine this, we can diagnose your error codes for you.
Please contact us at: from 7 AM until 9 PM CST and we will attempt to get your washer repaired for you.
We look forward to working with you. Thanks, Ella
Nov 13, 2009 | Kenmore HE2 Plus Front Load Washer
My kenmore he frnt load washer has an error code of (f24). tried the manual solution no luck. can you help me?
On this model of HE washer, the F24 code indicates that the water temperature sensor is out of range (23 degrees to 217 degrees F). This usually indicates a bad thermistor (temperature sensor - Key 24 in the image below). A bad wiring connection or a failed control board could also cause this problem.
Good luck
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F24 error code
Take off the lower panel of your washer and under this panel on the back of panel is a book which tells you what the error codes are and how to fix them or test for them. It looks like a tempature sensor code to me.
Apr 19, 2008 | Kenmore 46462 Front Load Washer
Open Questions:
Washing Machines Logo
2,140 people viewed this question
Sal De
 Brian Main
Brian Main
