Agitator won't agitate
Dear Sir,
I really hope you can send this to my email becuase I'm not sure I will find your answer among all the answers on this site.
Here is my problem: The machine I have is a Kenmore 80 series, heavy duty. The model number is 22892100. The serial number: CL 421 9011. Type: 111, Amps 10, Volts 120, Hz 60.
The agitator won't spin. There is also a blue lock ring around the center of the agitator (you probably know what I'm talking about) that I lifted up to unlock. I can pull the up but it doesn't come off. It just feels like it's springed-locked in place, kind of thing. If I had a manual, I could probably figure out how to get it back in place so that it will agitate again. But I bought it second hand, just a few years old and they lost the manual. Can you help? I'm kind of desparate to get it into use as it is our only machine.
Thanks alot!
  • 1 more comment
  • dlutz1005 Dec 18, 2008
    Thank you. I will check according to your directions and see if I can accept this solution. I will get back to you. Thank you very much. A little challenge, I am partially disabled. I can not do this alone. Give me time to find someone to help me.
  • dlutz1005 Dec 20, 2008
    I tried first, before anything else, to be sure the lock ring around the agitator was firmly in place. This seemed to solve the problem! Thank you.
    Thank you for offering all your helpful troubleshooting ideas. As it turns out, the solution was a simple one. Appreciate your service. Will keep your ideas in case of future problems and did find it helpful to know what you shared.
  • Washing Mach... Master
  • 8,220 Answers
Your machine probably has a broken coupling.
Click here for explanation
Posted on Dec 18, 2008
    Master:
  • 416 Answers
Check the following: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley. Transmission The transmission may have a worn or broken gear, or some other internal problem. Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Good Luck
    Sergeant:
    Novelist:
  • 327 Answers
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Sergeant:
  • 306 Answers
Sounds like a stripped gear or a stretched and loose drive belt. You have to turn off the water and disconnect the hoses and turn the washer over on it's side and check from the bottom. You will see the belt and see if you can rotate it without the gears (pulleys it goes around) moving. You hold one of them and then try to turn another and if it turns then the belt is loose enough to slip. On the main (Center) shaft is where you want to hold the belt and see if the pully will turn. If so it is loose on the shaft and there is probably a screw on it to tighten it to the shaft. If the belt is stretched max cost should be about $25.
  • AbdulRahiman S Dec 18, 2008
    else its a good chance the coupler is broke. If the lid switch is bad your washer won't spin,but the motor also won't hum. So I doubt the lid switch. Could also be something in the pump stalling the motor. More than likely the coupler bad. Common problem on these washers. u will hav to replace the coupler..
Some keys in my keyboard of hp mini 1000 are not working properly
how much would i pay for a change of keyboard f ever it doesn't really works? please send me answer on my email. i really need this to fix. i just borrowed this mini notebook. or any other options to fix it manually by my self? my backspace doesn't work. send me answers on my email please. tumulak_myra@yahoo.com
Oct 08, 2011 | HP Mini 1000 Netbook
We have a Crosley CSWS16445WQ washer and can't get the agitator out to clean it. Can you help please?
http://www.searspartsdirect.com/partsdirect/part-model/Crosley-Parts/Washer-Parts/Model-CSWS16445WQ0/1502/0153200/W0907160/00003 hello jbick, here is a diagram that might help. Once you get the bolt out, you have to pull them up unless they're corroded onto the shaft. A well-know trick that I may do slightly different is to take 2 loops of rope and slip them underneath the agitator at the bottom. take a 2x4 and run it through the top of both loops and use the washer top as leverage to pull the agitator out. use a good towel or something to protect the finish on the washing machine. I hope this helps solve your problem. It's really aggravating sometimes to have things that are stuck, and to be struggling to remove it. If you have anymore questions, feel free to send a reply. I would love to help if I can, or find the answer for you.
Good Luck'
mike
Jul 16, 2011 | Crosley Washing Machines
How to remove agitator on Maytag sav3655aww
Hello, All you have to do is remove the softner cap and there is a center bolt, Remove the bolt and lift up on the agitator thats all..Hope this helps. Please Rate My Answer.. Thanks
Jun 09, 2011 | Washing Machines
How do I take the agitator apart to clean it?
Sorry to read about your problem, I hope this helps you out.
you do not really take the agitator out to clean. but if you wish to remove it.
1. you will remove the top dispenser from the agitator, then you may see a protective cap or you will see a screw, remove cap and or screw.
2. then remove agitator, it maybe hard to remove.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 31, 2010 | General Electric WBSR3140GWW Top Load...
Can't get the fabric softner cap off
Don't feel foolish as im sure your not the only one this has happened to. to remove the agitator cap you must lift it off, apply slight twisting to it while your doing this. soap can gum it up so you may have to use a straight screwdriver to assist you. once you have done this, there should be EITHER a set screw for an allen key on the SIDE of the agitator OR a 3/8 hex screw in the center or the agitator. there is a spring under this screw so remove both and the agitator should lift staight up. use an old belt underneath the base of the agitator for better results. i hope this has answered your question.
Thanks
Aug 08, 2009 | GE WJRR4170E Top Load Washer
Agitator seems loose. Makes loud noise at the end of the cycle (not a balance problem)
Did not fix it.   But for a few dollars I can send you my answer on "HOW" we did it.... kind like the offer you gave me.
May 01, 2009 | Washing Machines
Agitator loose after dog replacement
Try RepairClinic.com thats where i get all my parts
Mar 02, 2009 | Whirlpool LSR7333 Top Load Washer
WFT 802
if agitator is the problem then you can buy the parts from this link.
http://www.apart4u.co.uk/cgi-bin/ss000000.pl?RANDOM=NETQUOTEVAR%3ARANDOM&PAGE=SEARCH&SS=agitator+&TB=A&PR=-1&GB=A
ive read some problems lately like you are and his problem was on spining of his washing machine. someone told him that the problem is the agitator so maybe your problem is just like him. agitator problem.
by the way im sorry madam for calling you sir. i just didnt notice that your a woman. im very sorry for that!
cheers
CHARCOIS
Sep 01, 2008 | LG WFT1071TP Top Load Washer
Need help
If the header you used is correct, this is how you would remove the agitator for a Whirlpool:
1. Remove softener dispenser (if equipped with one on the agitator) or the center cap.
2. Under the center cap should either be a bolt or a recessed square socket. Loosen the bolt with either a 7/16" or 1/2" socket. If you have the square socket, use a 3/8" to 1/2" adapter.
3. Once the bolt is removed, remove the upper agitator auger making sure you keep all the small components together.
4. Grasp the agitator flanges near the bottom where it meets the wash tub and pull straight up. The entire agitator should lift out.
I hope this is the answer you were looking for. Let me know if you have any further questions.
Feb 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
