Question about Zanussi F1245W Front Load Washer
The Washing Machine fills and then empties with not running a wash cycle
Zanussi zwx1605 the Washing Machine fills and then empty with not running a wash cycle you can hear the pressure switch click once then the water stops and then starts to fill again and then it starts to empty if you can help i would like to say thanks know john
  • 3 more comments
  • luscious Nov 05, 2007
    tried turning machine off at wall to erase memory and use different wash cycles but does the same to all can put machine onto spin and the machine does this
  • Anonymous Mar 12, 2014
    On any programme, machine empties water, then fills and then stops. Hot smell coming out
  • Anonymous Mar 16, 2014
    Stops filling and won't start wash cycle
  • Anonymous Mar 25, 2014
    replaced fuse in control panel and the machine worked long enough to fill up and start washing but then fuse blew again
  • Anonymous Mar 31, 2014
    Fills with water but then will not run throught the cycles
    President:
  • 1,462 Answers
Possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Posted on Mar 27, 2007
Hi my zanussi washing machine will only spin slowly and there is scale in the drum and on the clothes
the evacuation pump is either blocked up
or not running
i would remove the blockages
then run through an empty load cycle of 95deg white wash and some calgon tablets
Mar 09, 2015 | Zanussi Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Zanussi E30 problem
hi this can be caused by an earth leakage on the motor or more likely the heater it only needs a few mAmps to do this. you need an insulation tester to find which is the culprit. or try disconecting the heater to see if you can get the machine past the fill stage.
Jul 30, 2010 | Zanussi FJS1225W Front Load Washer
Zanussi washing machine, conditioner doesn't empty
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2009 | Zanussi ZWF1430W Front Load Washer
Check your filters first, then the pump. Refer to your manual; or click troubleshooting above.............sure would get some tips.
Jan 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 16, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi turbodry 1050
this may sound silly but check the waste outlet pump electrically, some models are wired up so if the pump fails the water will not enter the machine, this works on the theory that if it fills up it can not empty also check the solenoids for open circuit electrically, double check the water supply to the machine, it may have been fine but you could have kinked the pipe placing the machine back where it should go?
Oct 04, 2007 | Washing Machines
Washing Machine
I don't have any experience with Zanussi, but sounds to me like the inlet water valve needs to be replaced.
Aug 08, 2006 | Zanussi FC1200W Front Load Washer
Zanussi F1245W Front Load Washer Logo
694 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
