Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Error code EO -F2_
What does this mean and how can I fix it?
  • colemanater Dec 21, 2008
    Thank's so much for your help. I really appreciated your input. I'm now up and running!
    Jim
  • markhessler1 Dec 22, 2008
    I Have same problem came EO i did unplug then never came on.
    If someone can help how to fix it i wrilly appriciate.
    Regards:Mark
    my e-mail is markhessler158@hotmail.com
I had a problem with the control panel, the LED goes out and we have to feel the clicks to determine the temperature, already replaced the CP twice, no change the LED goes out intermittently - without warning - please help!
Posted on Oct 18, 2009
  • 8,197 Answers
It means that your control panel went out and you need to replace it. Here is how if you want to try your self.
The control panel is not available as a complete part.
To replace the control or touchpad, pull the range away from the wall and disconnect the power to it. Remove the cover on the rear of the control panel. Remove the screws that hold the clock or control to the front wall of the control panel. These screws also hold the touchpad to the front of the control panel. The touchpad connects to the control with a ribbon connector and there is a locking tab holding the ribbon connector to the control. Lift the locking tab and unplug the ribbon.
Posted on Dec 18, 2008
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: EO F2 code
F2 E0 code is attributed to a short keypad with the Electronic Range Control (ERC). The recommended solution is to replace the ERC. If you can post back with comments I can locate a part number for you if you can give me the complete model number of your range (located along the opening around the oven door or lower drawer assembly). The model number includes a three-digit prefix. I would also need this to determine the manufacturer. This way I can research to find a part number and price and see if this is a repair you would wish to pursue. ERCs can be expensive on some models. I hope this helps you.
Posted on Nov 12, 2007
SOURCE: Error Message: EO -F2-, but I don't have a manual
Actual Solution: I justed fixed EO F2
1. Disconnect the power for 30 minutes!
2. Once reconnect the power, press the "cancel" button for 3-4 sec, this two steps serve as reset.
I have a Whirlpoor gas range and it has error message EO F2 for few weeks now. After searching on internet for possible solutions and didnt find anything working, I called Whirlpool thinking as a last attempt before calling expensive tech. people.
They told me exactly the above two steps, I came home and tried, it worked like a charm....
Note: Disconnect for 30 min, I tired 1 minute as some suggested on internet and didnt work.
Posted on Jul 24, 2008
SOURCE: Error message EO-F2 on Kenmore range/oven
model790.9503 gives f31 code
Posted on Jun 24, 2010
What is the eo f2 error code mean on a whirlpool oven
E0 F2 is a stuck key on the keypad. If your keypad is not available from the factory you may find a replacement unit here: http://www.fixyourboard.com/ledgestone.html
Aug 17, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
What does the error code F2 EO mean?
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 21, 2010 | Whirlpool Accubake RF362LXTT Electric...
Kenmore model 95781000 shows error code EO-F2- what is the definition of this code?
Hi
Thanks for using FixYa. Error E0-F2 means shorted keypad and to resolve this issue you’ll have to replace the electronic range control/keypad assembly.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore Kitchen Ranges
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
EO F2 on our Kenmore oven keeps coming up.
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
Kenmoore Electric Range - Error Code EO F2
That code means your oven is a piece of ****. Put out in front lawn on big garbage day. Get inside the oven and wait until the garbage men get there. Jump out and yell, "Surprise!". After you've had your fun go back inside, get your keys, and drive to the closest appliance store to get a new one.
Oct 05, 2008 | Kitchen Ranges
Errror code
HI. thanks for the question. the fault code EO F2. means the touch pad key board is the problem. to repair new parts listed . thanks the appliance doc
Sep 16, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Mar 04, 2007 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
375 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
