Question about Xerox DocuPrint P8EX Laser Printer
Paper jam in p8ex
The Xerox p8ex transports the paper for about 2 inches and then stops. The problem started when I cleaned the printer. I have taken some obvious parts out of the printer to remove the dust and toner from the unreachable spots. I have also tried cleaning the excentrical rubber roll that collects the paper from the tray by turning it. When I put everything together again and inserted a brand new toner cartridge, the printer seemed to be working properly, but when I tried to print a page it stopped after 2 inches. It doesn't transport the paper any further. Before I start to order spare parts randomly, I would like to know if there is anything I can to to repair it. And if not, which part should I replace? Thanks in advance.
  • 16 Answers
SOURCE: Xerox DocuPrint P8ex
In order for me to deal with this query for you i need get some informations:
- what operation system does you computer have?
- Are you gonna connect via parallel, USB, or External Ethernet Adapter
Fran10
Posted on Apr 10, 2008
  • 406 Answers
SOURCE: Xerox Phaser 7300dn
Dear try upgradiing the firmware. And if possible contact authorised service center for further assistance. Else update for further assistance
Posted on May 28, 2008
SOURCE: Xerox Phaser 7750 parts
Hi, I have 2 broken down phaser 7750 machines for spares. 250V. Perhaps I can help but I am in Nairobi, Kenya!
Posted on Jan 06, 2009
  • 2072 Answers
SOURCE: Frequent paper jams on Xerox PE220
You have to spin them backward to get them into a good position to clean them, They will resist you, but just take it slow and clean them with alcohol or formula 409 type cleaner.
But what will often cause jams on that machine is the seperation pad that is located on the paper tray itself. It will get very slick and allow 2 or more pieces of paper to feed, It is a small gray to black pad on the middle front of the tray, about 1/4 inch wide and and inch or so long, If it is smoothe scuff it with some scotch brite then order one or two.
Google a business called "the parts drop" and call Britt, they should have the pads and rollers at a fair price.
Posted on Feb 09, 2009
SOURCE: 8400 Phaser has paper jams which leave junk on the drum.
hi david i hope i can help you? you may need to give the machine a good clean, if there is any rubber wheeles? give them a clean with meths. little rollers check to see if any carbon brown in colour. its caused by constant use. i hope this has helped you? top tip you must make sure all the brown is completly away. to make your machine run better.
Posted on May 04, 2009
Automatic feed does not work
The wheels that are supposed to grab the paper might be dirty or broken, the reason can also be that the sensor that should see the paper doesnt work for some reason.
Nov 14, 2011 | Xerox WorkCentre XL2130f Laser Printer
Paper jam to the right before printing starts
your paper must be jamming because your are not putting paper properly in the printer
Apr 01, 2011 | Canon PIXMA MX340 Wireless Office...
Paper jam in a Xerox Comy Centre C20
A couple of things.
There is a bushing at the front of the exit transport that fall out of the frame. That requires removing the scanner and looking in the exit transport that way.
You may also have something stuck in that transport. Take the fuser back out and then take a minella folder and push it through from above the fuser to the output area and see if it disloges anything. If not, then you have to pull the scanner off and look in that exit transport area for problems.
Jun 26, 2010 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Xerox M15i paper gets jammed above the fuser "paper jam 2" fuser is hot but i think its supposed to be. Almost every sheet gets jammed.
Yes it is supposed to be hot. Let is sit off for an hour.
Open the right side as if you were removing a jam. You will see 4 silver phillips screws. Remove them, unplug the fuser and slide it out. I think you will find either a paper folded up in the fuser or in the paper path just past the fuser.
The fuser itself probably needs rebuilt or replaced.
Sep 29, 2009 | Xerox WorkCentre M15i Laser Printer
Cleared paper jam, but printer not responding
Did you shut power when removing the jammed paper. If you did not then you have forced the gears against the rotation and may have hurt the transport system
Jul 27, 2009 | Xerox Phaser 6100/BD Laser Printer
Feb 09, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Paper jam related to Maintenance Kit
I wonder if you got some of the silicon lubricant from the maintenance kit on the rollers.
Try taking some alcohol or a cleaner such as fantastic, 409 etc and throughly clean all the rollers in the paper tray and along that transport behind the door.
If it isn't getting out of the tray you may coincidently have a smoothe feed roller, if it is feedinf a couple of inches out of the tray and stopping in the lower rollers I suspect a slipping registration clutch. Removing the maintenance kit seems like an odd thing to start a jamming problem. As I said clean the rollers, I guess see if you happened to have gotten a chunk of ink in the paper path from the catch tray.
Is there any damage to the paper? And tears or dents in the page?
Let me know we can resolve the problem.
Jan 07, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 5500 printer...paper stops halfway thru fuser unit.
Are the paper tray settings correct? If you have the tray mis adjusted, such as the tray thinks it has 14 inch paper in it and it has 11 inch, it will just shut down like that.
Make sure the settings are correct on the computer and the printer.
Also, its unlikely but the latch for the load springs in the fuser may be unlatched, but you shold NOT be able to close the covers like that.
Jan 06, 2009 | Xerox 5500/DT Laser Printer
Xerox DocuPrint P8EX Laser Printer Logo
67 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
