See if you are getting power to your gauges. You could also check continuity between the fuse and the wires/pins into the gauges. If you know your getting power to the fuse check those things. If your not getting power to your fuses for these items work back from there. If you are getting power to the fuses and power to the gauges you probably have a bad ground in that circuit. Hope this helps.
SOURCE: I have a 2004 Chevy
Bad Stepper motors....the motors in your cluster are very weak... there is an upgraded motor x 25-168...cost 175.00 parts and labor to replace all of them. Ive repaired a lot of clusters with this very problem
SOURCE: 1996 ford ranger odometer / trip stopped working
Since your speedometers work, the problem is in the gearing to the trip and mileage odometers. Simple problem, major pain to fix but, remove instrument cluster - you'll have to remove speedo cable to get it out. Use the old Mark I eyeball to check for broken parts. Might even have to drop steering column - disconnect air bag first!
SOURCE: 2000 ford focus speedometer stuck at max speed
it may have a static charge in the instrument cluster,try un-hooking the battery then turn the key on and even hit the brakes to try to drain the spark out of the system,hooking the 2 cables together with the battery disconnected may work as well to drain it.hook up the battery and see what happens,but make sure the key is off and nothing is on-lights,radio,wipers etc,it could send a spark to the computer.
SOURCE: dashboard gauges dont work, 1998 dodge caravan
These vehicles seem to have a problematic short, my grandfather has the same vehicle with the same problem, i found the short under the carpet on the driver side of the vehicle, under the gas pedal, sometimes wires can crack and break.
MIKE
SOURCE: Speedometer not registering right speed.
replace a capacitor behind the panel (6.8uF 25V) with the new one.
