Hcn529w TV screen squished in on all 4 sides
Have replaced the convergence board twice. have put in the convergence board kit with the better resistors and pico fuse. Still has not fixed problem.Perfect focus does not work and cannot fix red blue and green crosshairs manually. Had a tech look at it he said the convergence board is missing a signal to it.What do you think.TRying to replace the def pwr board. Have to try something. Please help if you can
  • jchad005 Dec 21, 2008
    the digital convergence board. Will try the digital amp next.
  • Sonny Berry
    Sonny Berry May 11, 2010
    Did you replace the convergence amp board or the digital convergence board on your model/
  • 8,617 Answers
The Convergence amp board should take care of the problem.
Posted on Dec 21, 2008
I bought this new 4 years and I'm deeling with green and red issues mostly on the left side
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 22, 2010 | Philips Magnavox 51MP392H Rear Projection...
My samsung hcn529w rear projection tv has convergence problems. how can i manually adjust the color guns
you are reaaly looking for a nightmare messing with the convergence rings to adjust the convergence you need to change the two ics and probly some reistors
May 18, 2010 | Samsung HCN529W 52" Rear Projection...
Convergence board
Your TV most likely has one or more possible problems. You do not need to replace the whole board. Just the bad components.
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo2_bing.gif STK chips, convergence resistors, pico fuses, etc.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Nov 30, 2009 | Televison & Video
Samsung rear projection TV audio no video
There is a problem on the deflection board (BP94-00501B). I have tried replacing the flyback, both convergence IC's and the horizontal output transistor without any luck. I finally bought the whole board from encompass parts for ~$120. Hope this helps.
Sep 23, 2009 | Samsung HCN529W 52" Rear Projection...
Convergence problem
  • Screen looks 3D
Mar 05, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
  • Screen looks 3D
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Picture is squished in on all 4 side of TV and colors are all dis
You will not find the problem in deflection board it will go back to convergence board,I repaired one that would not Magic focus cause was on connectors from power board to convergence board the one closes to up front of board one of the pinns was bent under so when i pluged it back in did not know after lifting up connector under tiny pins 1 of them was bend under straighten it so it could plug in right Fixed problem.
Dec 17, 2008 | Samsung HCN529W 52" Rear Projection...
QUestion.
Replace Convergence Ic's or convergence amp panel
Jan 05, 2008 | Samsung HCN529W 52" Rear Projection...
Convergence board replace, still cannot manually adjust covergence
Do you have everything pluged in?
did you get a new board or repaired board. I think it's defective if everything checks out
Apr 14, 2007 | Samsung HCN529W 52" Rear Projection...
Panasonic PT 47WX51 TV troubleshooting
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Mar 25, 2006 | Panasonic PT-47WX51 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
