Question about Hardware & Accessories
How do you operate lamp timers
I've got a Intermatic Model TN300. Instructions are lame. Don't know how to setup. Please help
  • 3 more comments
  • Anonymous Dec 25, 2008
    i have the same timer! i dont understand it either :/
  • toribray Dec 31, 2008
    I am going crazy over the same problem with my Intermatic TN300. Purchased this and have no clue how to set it up. Please help asap, thanks
  • Anonymous Jan 10, 2009
    I have the same problem and can't find anything on Intermatic's website. Any suggestions?
  • trdavid Feb 26, 2009
    I have the same problem with the intermatic timer - the time of day arrow moves along with the entire dial, and I don't see how it can be set at time of day!
  • toribray May 11, 2010
    Thanks for the posting, I have checked those directions as well, but they are the same ones the timer comes with. I have been doing exactly as you and the directions say and it does not work.
Yay!!! I found out the solution, and I tried it, and it DOES work!
I got these instructions from Intermatic Technical Services. I e-mailed them with my problem and they finally got back to me.
Follow them exactly and you will have no problems!
1) Pull up all trippers.
2) Push down the tripper at the time you want the light to turn on
3) Push down the tripper at the time you want the light to turn off
4) Push down all trippers for the duration of your on time
5) Set the current time of day with the time of day arrow
6) Plug in your lamp and make sure the lamp's switch is in the on position
7) Set the slide switch at the top to the timer position
If this does not help, please contact technical service by phone at 815-675-7000, option 1 then option 2.
Posted on Jan 21, 2009
This is what worked for me!!!! Finally!!!!!!
1) Push all trippers up
2) Set time of the day
3) Push tripper down from when you want it to go on
4) Push tripper down from when you want it to go off
5) Push down trippers in between the on and off trippers
6) Set the top swicth to the "timer on"
7) Plug in your lamp or christmas lights into the timer (make sure lamp is on the ON switch)
8)Plug the timer into wall socket
Posted on Nov 21, 2009
  • 16 Answers
Try this link.
http://www.intermatic.com/images/instruction_sheets/tn300.pdf
Make sure all the pins are up. Then set the dial to current time of day. Then push in the pins of the times you want it on and off. Plug it in th esocket and plug in light/device to be controlled.
Sounds like when the internal motor runs around, each time it hits a set point it alternates between on/off. If you have two points set it will go on/off once per 24 hour day. Four will give you 2 on/offs per day.
Posted on Jan 12, 2009
How do I set the woods tn300 timer
just found this on the fixya site not sure if its what you are looking for.
Woods TN300 and Intermatic TN300 and Woods 59200 are same timer:
To confirm this is your timer, open link below
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
If this is not your timer, then add a comment for additional free service.
Instructions:
Rotate dial to set current time, when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour. Push segment down like piano key.
Segment pulled up = lights OFF
Segment down = lights ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Oct 22, 2017 | Woods Hardware & Accessories
I do not know how to set it. i have lost the instructions for a 111woods model tn300
Woods timers sometimes have more than one number for same timer.
This is true for most brands of timer.
Companies change model numbers and add new model numbers.
Intermatic makes two different analog timers with 111 model number. TN111 and HB111.
Grasslin has older electronic timer Tactic 111
Timex sells TE111 timer.
Open following link to identify TN300 analog timer and read instructions and download possible manual:
If TN300 is not same as your timer, view images on link and then add a comment for possible help with different timer.
Open following link for instructions how to set analog timers.
http://waterheatertimer.org/How-to-set-timers.html
Sep 02, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I lost instructions for Woods TN300. How do I set it?? THANKS and HAPPY NEW YEARS to all and BE SAFE!!!
Instructions:
Turn lamp ON
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone to help you solve problems
Jan 01, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
I HAVE INTERMATIC MODELTN300 and don't know how to set it up,
Intermatic TN300 timer is same as Woods 59200 timer
See timer at Amazon
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Timers are sold under different brands and numbers depending on who is packaging and marketing the product.
59300 manual:
http://waterheatertimer.org/pdf/Woods-59200.pdf
Turn lamp ON
If instructions above don't match your timer, see following page to identify timer:
Dec 14, 2010 | Hardware & Accessories
I neeed the instructios for woods timer TN300 thanks
59300 manual:
Turn lamp ON
Dec 13, 2010 | Woods 59200 Lamp and Appliance Timer with...
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Turn lamp ON
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
No instructions!
Open following link to identify Woods and Intermatic TN300 manuals and see written instructions.
For troubleshooting and photos of timer dials.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 05, 2009 | Intermatic 10 Amp Mechanical Indoor Timer
Not running when I set it
For troubleshooting instructions and photos of timer dials.
Upvote the help.
Apr 30, 2009 | Intermatic 10 Amp Mechanical Indoor Timer
Hardware & Accessories Logo
8,153 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
