Question about HP JetDirect 610N Print Server
610N dissapeared no lights, empty EIO, reset no help
Got it to reappear once when printing Config pages. but gone again after power cycle. No ethernet. Is it a power problem? Does it need a reflash? should I just buy a new one. I've heard there are problems.
  • 22 Answers
If you're seeing it intermittently, try the following:
-remove it completely
-power cycle the printer with it out
-check your contacts (be sure no bent pins, etc)
-Try it in a different slot if you have one (most HP's with an internal jetdirect have 2-3 EIO slots, but since you don't mention what model printer you have I don't know for sure).
If it's not talking after all that, likely the jetdirect is actually dead. It's been known to happen. I wouldn't waste the money on a replacement, you'll have better luck getting an external card and it'll be cheaper, too.
HP sells both the JetDirect 170X and 175X externals; there's also the Linksys PSUS4, D-Link DP-300U, TrendNet TE100-P1P, or Netgear PS101NA. Price will vary between $45-80.
Posted on Nov 09, 2007
Error 09B207 007A0F4F
Switch the Printer OFF and ON again and wait for the initialization. If the Error code continues to appear, switch the Printer OFF. Remove the EIO Card (if installed) and make sure that the Hard Disk Drive is installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the Printer ON again. If the error codes 09Axxx or 09Bxxx appear then replace the Hard Disk Drive. If the Error Code disappeared after removing the EIO Card, then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If the Error Code reappears, then the EIO Card could be faulty. Replace the EIO Card. If Error Code 09Cxxx appears after initialization, then replace the Electronics Module. Once the Error Code has been solved, print an Internal Demo Print to make sure that the Hard Disk Drive is functioning correctly. If the Error Code reappears, then use the above information to troubleshoot the problem.
Dec 22, 2015 | HP DesignJet 1055CM Plus InkJet Plotter...
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
49 FF81 error on HP Laserjet 3035xs MFP
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter (see Formatter on page 116).
Apr 03, 2012 | HP LaserJet M3035xs MFP All-In-One Printer
I need to find the IP address of my HP Laserjet 4200n printer. I've gone through all menus, printed a configuration page, and nothing. How can I find it??
First look at the back of the printer where the network cable plugs into the formatter. There should be a blinking green light. No green light no network!
That means printer is talking to the host.
Print out the config pages again. On the 2nd page top left side should be a line "I/O card Ready"
If it is READY, look down the page and you should see the IP address.
You can also push the left side of the menu switch twice. You will see EIO X JETDIRECT MENU
That is where you find the IP address.
Apr 19, 2011 | HP LaserJet 4200 Printer
HP4550 - 49.00FF service error
Turn off the RAM disk on the printer.
Follow these steps:
Troubleshooting steps
1.
Verify that the formatter light is blinking or steady. If the formatter is blinking, it is functioning properly and probably does not need to be replaced. If the formatter light is not blinking, proceed to Step 2.
2.
Turn off the printer and unplug the power cord.
3.
Remove the HP Jetdirect card, third-party device, hard disk, parallel cable, or IFR cable from the formatter if one is installed.
4.
If the error continues with accessories removed from the formatter, perform a cold reset on the printer. Ensure the HP Jetdirect card is not in the printer during a cold reset or the card settings will be changed back to default settings. To perform a cold reset, do the following:
1.
Turn on the printer.
2.
Watch the control panel.
3.
When the memory starts counting, press and hold the green (Select ) button.
4.
Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
5.
Release the check button when the Ready, Data, and Attention light are on steady.
The control panel will display SELECT LANGUAGE .
6.
Press (Down Arrow ) button once. The control panel will display COLD RESET
7.
Press (Select ). The printer will perform a cold reset and then continue its power-on sequence.
5.
If the printer comes up to ready, print a Configuration page. If a 49 error occurs from printing internal pages, continue on to the next step.
6.
Turn the printer off and unplug the power cord.
7.
Remove the eight screws around the formatter.
8.
Remove the formatter. See Figure 1.
9.
Reseat the firmware and memory modules on the formatter. Check for any DIMMs that are non-HP and remove them. Non-HP DIMMs are not supported by HP and may cause this error. Replace with HP DIMMs, if necessary.
10.
Reseat the daughter (interconnect) board. The daughter board is connected to the formatter behind EIO slot #1. To release the daughter board, push in the black retaining tab underneath the formatter then lift up the one side of the daughter board.
11.
Reseat the daughter board.
12.
Install the formatter.
13.
Turn the printer on again.
14.
If it comes up to READY , print a configuration page. If a 49 error does not appear from printing internal pages, or at power up, continue to the next step.
15
Install the HP Jetdirect card and hard disk before installing the formatter. Verify that each device is properly seated.
16
Test any EIO devices, by turning off the printer, installing each device separately, and printing a Configuration page. Repeat for each EIO device.
17
If the 49 error occurs with any EIO device installed, replace that EIO device.
Oct 05, 2010 | Computers & Internet
I have both green light next to the rj45 on my jet direct 610n, but my jet direct doe not show when I print the configuration page, I tried cold reset didn't help. Any idea howni might be able to...
If your JetDirect Ethernet card does not show up on the configuration page then the JetDirest is bad. This is somewhat common with the 610N cards. You will need a new card. They are cheap to buy just about anywhere including Ebay. I have replaced dozens of them over the years.
Sep 12, 2010 | HP LaserJet 4100tn Printer
HOW TO GET METER READING?
Switch it on and load paper.
Press the red and green buttons together, and several pages should print out, test page, config page, and perhaps a EIO or network config page.
The second page should show the page count.
Feb 03, 2010 | HP LaserJet 2500 Printer
NEED TO RESET MAINTENANCE MESSAGE
Turn the printer off. Press and hold the select and return buttons while powering on the printer. Release the buttons when the display shows "Perform Self Test". The printer will continue to boot-up. When ready the display will show the word Config Menu. Then press the menu button untill you see the Reset Maintenance Count option. Then press the select button. The reset command shows on the second line of the menu. Press the select button again to reset. Now press the menu button untill you see the Exit menu and press select. The printer will now automatically reset itself and boot up ready to print.
Apr 26, 2009 | Office Equipment & Supplies
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
n If the Error Code disappeared after removing the EIO Card, then
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Not able to take print on both side in hp 9000 normal series
You can't print on both sides you miss • Automatic duplex unit for two-sided printing" you're model doesn't have it.
Read below:
Shown at left:
HP LaserJet 9000 series, base unit—
LaserJet 9000
base unit =
• 50 ppm print speed
• first page out in less than 8 seconds
• built-in RIP-once technology
• 300,000 pages-per-month duty cycle
• 64 MB memory
• EIO expansion slots
LaserJet 9000n = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TX
• 100-sheet multipurpose tray
LaserJet 9000dn = base unit +
LaserJet 9000hns = base unit +
HP Jetdirect 610n (EIO) internal print server for Ethernet 10/100Base-TXlj9000hns.jpg
• 2000-sheet input tray
• 3000-sheet stapler/stacker
Oct 25, 2008 | HP Compaq dc5700 Microtower - Free Flat...
HP JetDirect 610N Print Server Logo
1,001 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
