Charging issue I am using emerge UPS for my PC. Should I keep the UPS under charging all the day long or can i turn it off once the GREEN light indication is shown?
    Scholar:
  • 139 Answers
Since u did not specify the make and model of the ups.
i'd advice u to keep on charging mode allday long.
it wont do any harm to it.
hope this helps.
Posted on Dec 27, 2008
  • Agugua  Lims
    Agugua Lims Dec 27, 2008
    since u did not specify the make and model of the ups.
    hope this helps.
Charging light flashes quickly between green and yellow. Normal?
No. Most UPS's should have a Solid Green Led on if the unit is running good. This might be indication that UPS has batteries that are not charging completely which mean they are depleting. How old is this UPS and the batteries? Have you changed the batteries yet? Need more info. Do you still have the manual. Always keep UPS manual handy. I have a ton of manuals but not for these little UPS. Mine are for 10kVA to 1000kVA 480v to 208v. Anyways hope I helped.
Dec 21, 2013 | Hi-Capacity Zoeller 510-0005 Basement...
I have a CyberPower 725SL UPS. Shortly after turning it on, it will beep as if AC power was lost and the green light goes out. I checked the battery and it's good. I'm assuming something went bad with...
Couple different items to check.
  • Try letting the unit set ideal for overnight charging the battery. Do not even turn the unit on.
  • Replace the battery.
If you turn the unit on when the battery is plugged in and does not keep a charge you can almost be sure it is the battery or the charging circuit not maintaining the battery.
Nov 11, 2010 | CyberPower 725SL UPS System
Battery Recharge for Liebert PowerSure PSA
Yes, is the short aswer to your question. The battery should charge as you use the ups. If they don't then its likely the battery/s have failed. Lead acid batteries do not like being left discharged for any length of time. In a motor vehicle the battery gets a bit of shaking around, but in an ups they don't. If not used and left discharged, the plates quickly sulfate up reducing the efficiency to nearly zero. Test and replace any battery that cannot support a test load, such as a bright12v light or a 12v soldering iron connected to it. The length of time required to charge the battery/s depends on their capacity (in ampere/hours) and the charging rate. A 14.4 amp/hr battery charged at say 1 ampere will take 14-1/2hrs to charge.(just as a sample)
Apr 25, 2010 | Liebert (PS1440RT2230) UPS System
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
Smart UPS 1500 - battery level green lights blink on and off
You need to run recalibration on the unit.  The supplied PowerChute software & cable will allow you to do this if you hook the UPS up to a PC (I know it works with the serial cable, not sure about USB).  If you only have a MAC then I cannot offer a solution other than to buy the standalone PowerView device from APC.  It will cost a bit more than a battery, but may save you from buying needless batteries in the future.  I finally broke down an bought one, but note that I was still having the problem after the 1st recalibration.  By trial and error (and maybe a vague memory) I put my MAC in sleep mode, that dropped the load to stop the lights from flashing.  Then I recalibrated with a 22% load and now it finally seems better (lights no longer flashing).  This was with a Smart-UPS 1000.
Let me know if that helps.
Apr 01, 2009 | APC Smart-UPS 1000VA UPS System
Apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
Mar 26, 2008 | APC (BE500U-WEB) (BE500UWEB) UPS System
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
New battery will not recharge
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
Dec 19, 2006 | QVS NetStar (UPS650A) UPS System
Computers & Internet Logo
83 people viewed this question
Alun Cox
David Payne
David Payne
