Question about LG Flatron L1750S 17" LCD Monitor
My 17in monitor was working just fine all of a sudden it quit .
No power I checked the power cord and it is fine. I plugged the LG into my other pc still no power.
  • Anonymous Jan 30, 2009
    My gf turned off my monitor overnight. I have the LG 19in. flatron wide. The next day it picks up no power at all. I've tried dif power cords and still nothing.
  • Anonymous May 14, 2009
    The monitor worked one day, then the next day the power light on the monitor was orange (power saving mode), we moved the mouse to wake it up and the power light went out completely and now the monitor won't work at all. We checked the power supply and connections and everything looks as it is should (has power and the connections are okay).
  • 115 Answers
Monitor is defective. It need repairs.
Posted on Dec 18, 2008
Desktop all of sudden don't display
Please follow the steps below
1. Please check the video port connection if properly plug-in it could be loosen
2. Please check if the power cord of the monitor is properly plug-in maybe it was accidentally disconnected from the power source.
3. Press the power button on the monitor ad check all the LED lights.
4. To isolate the issue we can use other monitor or we can try the monitor that is not working to other PC.Again,if the problem continues plase call the manufacturer or call the store where the item was purchase.
Sep 04, 2011 | HP Compaq dc7600 Small Form Factor PC...
The monitor which was supplied with a Compaq Computer 6 years ago was working fine. Suddenly,no power is coming into the monitor and it is blank. Can your customer service get this fully repaired? If so...
Firstly try plugging the power cod from your PC into the monitor and power it on. Are there any LED lights on your monitor? If there is, then all you need to do is replace the power cord with a new one.
If there aren't any, it means that your CRT's internal power supply unit is dead and needs to be replaced. However, replacing these parts can be quite costly and involves labor charges since your monitor is out of warranty. I highly recommend that you look into the option of purchasing a new LCD monitor as these are pretty cheap nowadays.
Anyway, here is the service centre in Bangalore dealing with Samsung monitors:
#8 WOC Road, Mahalaxmipuram Post Near Swathi Hotel, Bangalore - 560085 KARNAKATA
Phone : 23496985
Mar 11, 2011 | Samsung SyncMaster 793MB 17" CRT Monitor
Quit working
Hey there,
If your monitor has quit working then, unless you are a qualified technician, your only options are to replace the monitor or take it to a qualified service technician.
I would not recommend opening or attempting any repair on this product yourself.
All the best :)
May 10, 2010 | Envision EN-7410 17" Flat Panel LCD...
Monitor problem
no that is a problem of microcontroller chip inside the monitor ti becomes faulty because of virus inserted in the monitor and chip bacame faulty try if anywhere it formatted and reprogrammed
Mar 05, 2010 | LG Studioworks 700S 17" CRT Monitor
Desktop PC monitor suddenly went black & power light went off
1 either ur VGA card is corrupted or
2 RAM is corrupted
3 Last may be your motherboard is gone - not sure
Jan 04, 2010 | Computers & Internet
L1932TQ LCD Monitor won't turn on.
I'm affraid you did about everything you can to find the issue. Trying to isolate the problem is the best way to come close to a solution eventually. But after all the tests you did, it seems that the monitor itself got a problem. I dont suggest you to try to fix it yourself, some electrical parts may need to be electrically discharged before being removed from the monitor. If your monitor is still in waranty, contact LG for support. Otherwise, you could bring it to a local tv/monitor store to see if they can repair it. LG support rep could also give you some advice, maybe they got a certified partner in your area that could take a look at it. P.S. If your computer is on windows XP it should shut down the usual way just by pressing the power button once. The shutdown will be the same as if you go Start->Shutdown->Shutdown the computer.
Jun 03, 2009 | LG L1932TQ LCD Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Emachines computer problem
have you checked the cord and connection to the video card?also you could try resetting the bios.unplug the power cord on the pc.remove the batterie on the motherboard.power it back up.remove power cord again and replace batterie and restart pc.
Mar 04, 2009 | E-Machines eMachines Desktop PC
Doesn't work
First you check power cord by multimeter for ok .if it is ok then open the monitor and check fuse in power section.If it is ok then check pf in power section.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 21, 2008 | Advueu Technology ADV178T 17" Flat Panel...
Monitor doesn't work
When you got the pc, you should have been given a starter pack with some CD-ROM's in the pack, one of them should be the drives for the monitor, you might need to use anothermonitor to see the instructions, but the basic graphics card should power the monitor enough to set things up, until then you won't be able to adjust the settings.
Apr 17, 2007 | Kogi L7CH Monitor
LG Flatron L1750S 17" LCD Monitor Logo
173 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
