Question about Brother FAX 375MC Printer
Unable to get Fax Print
Fax is working fine, but when I try to do the copy, I get a blank page out. So is the case with Incoming FAX which is BLANK. please advise
SOURCE: Cannot Send or Receive Faxes
brother mfc 240c cannot receive fax. it can send fax only.
Posted on Sep 01, 2008
SOURCE: Will not print.
What a ditz, it just needed a new ink cartridge.
Posted on Jan 23, 2009
  • 167 Answers
SOURCE: Receiving Fax
- If the Printer is connected to a router, you have to configure your router to allow the communication on it.
Posted on Mar 11, 2009
  • 2306 Answers
SOURCE: Printing blank pages when receiving fax
Ask if the ones sending are sending legal size, it may be using 2 sheets to get all from a legal size document.
Posted on Jul 29, 2009
  • 7 Answers
SOURCE: Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Posted on Nov 21, 2009
SOURCE: Prints faint pages
I have the same problem. It appeared to happen only after I changed the drum but Brother says it's not the drum but could be the laser or something mechanical. It is totally random, sometimes it's fine for a week and other times it happens a few times a day.
It happens with printing and faxes. Not sure about copies.
Did you ever find a solution?
Posted on Jan 11, 2010
0 characters
1 Points
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
Incoming faxes are blank outgoing faxes work ok. toner has been changed
Hello sir; Try to make a copy, if copy is OK then replace a new phone cord .if copy not OK still blank, that's means high voltage supply board have problem.
Oct 12, 2009 | Canon L120 Fax Laser Printer
Recived faxes only print out blank pages
Someone sent you fax upside down. If your machine prints and copys OK, it's not your machine.
Aug 19, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Office Jet 630 will not print
please check whether the data cable rx232 which is used to connect the printer to pc is fine. try someone else's cable(e.g friend) and check whether it is able to print .re install the software that is provided along with the printer in the form og cd or dvd. hope your problem will be tackled then
May 25, 2009 | Printers & Copiers
Hp5510--will fax, bukt when it prints, the sheet is blank.
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
Dec 01, 2008 | HP Officejet 5510 All-In-One Thermal...
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
ok...try a test page first, with printer off the computer completely
and..check for newest printer drivers here
Mar 04, 2008 | HP PSC 2210 All-In-One InkJet Printer
Brother FAX 375MC Printer Logo
18 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
