Question about Brother MFC-8440 All-In-One Laser Printer
I cannot print to different size paper
I am trying to print a group of docs. Somer are letter size and some are legal size paper. I purchased the second drawer to allow legal size to print but the only way I can print legal size is to take the letter size paper out of drawer 1 and the printrt picks up from drawer 2 for the legal size. I cannot figure out a solution. HELP!
    Champion:
  • 320 Answers
You need to go to the printer set up on the desk top, there you can tell the printer what to do
Posted on Jan 14, 2009
Copying legal size on a Brother MFC 7420
This is for a temporary, as needed solution: Press "Menu/Set" button. Select "General Setup". Scroll down and select "Paper Size", find and select "Legal" size. Press Menu/Set button again. Press "Stop/Exit" button.
Insert legal size paper to be copied on the feeder tray and put a legal size paper in the Manual slot. Hit "Print"
You need to do these same steps again to return the settings to Letter size again.
May 09, 2012 | Brother MFC 7420 All-In-One Laser Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Scanned legal doc to email comes out landscape and prints on lett
select scan mode, then select legal on paper select. If you select paper before loading document into the ADF it should go with the size you enter.
Jan 07, 2009 | Sharp AR-M550N Copier
We had problems to print legal and after 30 minutes of trying it finally printed legal. Now we cant go back to letter size so every document prints on legal paper. Can I get clear instruction on how we can...
When you say printing? Do you mean from the computer or are you making copies. If you are printing from the computer you need to change the paper size that you are printing to under the printers properties or the out put tray. If you are making copies just hit the reset button or just manually select another paper tray on the display pannel. Or if you have change a paper tray to leagal size change it back to LTR and make sure the paper is installed the correct direction.
Nov 26, 2008 | Canon imageRUNNER 2200
Cannot print to legal size paper format
There could be a few issues causing this problem.
1. Your document size on the actual document you are attempting to print believes it is letter (which is the default).
To change this setting, you must tell the computer you wish to print on legal paper.
To do this in MS. OUTLOOK:
Put the curser at the top of the page
then...under 'File-Print-Preferences-Layout-Advanced-Paper size-change to legal (from Letter'
-slightly tedious...but follow along and this should help
2. The printer needs to be adjusted to hold the legal paper.
Open up the legal tray to adjust the paper holder to hold the paper snuggly...it slides roughly.
Hope this helps..if you need more assistance please ask...also please rate my solution.
PLEASE note that anything other than a FIX-YA is actually a negative rank...and will lower my success...I didn't make the system...but that is the way it is in FIX-YA.
thanks
bearb
Nov 10, 2008 | HP LaserJet 2605DTN Color Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Brother MFC-8440 All-In-One Laser Printer Logo
294 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
