Question about Acer 22" X223w LCD Monitor
Computer monitor screen is blue
I was on my computer and the screen suddenly turned blue. I unplugged it, turned the computer off, and rebooted it, and it is still blue. Any suggestions???
  • 115 Answers
Can you access the bios set up.
If the bios setup is running evrything is ok except the hard disk.
To find out if there is any problem with monitor just put off the monitor and disconnect it from the cpu. Then turn it back on. If the no signal message is coming, then monitor is ok.
Your hard disk is the main suspect
If the same blue screen comes then monitor need repairs.
You may also try with another monitor on your computer to see the results. If the sane happens it is the hard disk
Posted on Dec 18, 2008
My pc is showing a white screen when iys on
Is it an LCD monitor ?
When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
When i turn my pc on the moniter says no inputsignal being raceived.my monitor goes to sleep
if your monitor stopped working suddenly, then check if the cables are plugged in correctly. You can do this by looking on the backside of your monitor, check the connection of the power supply and the VGA cable (blue cap). Unplug it and plug it back again. Then follow the cables to the computer and the jack plug and do the same, unplug ang plug back in. Reboot the computer and reply here if there is something...
Jan 13, 2011 | Computers & Internet
My screen suddenly went blue (with twitching lights), although sounds still worked. Now, even when i reboot the computer, I only get blue screen, altough the computer turn on...
Make sure that the input on your monitor is on the correct selection.
Is this a dual monitor setup? If so unplug one of the monitors and restart the Mac.
Jan 06, 2011 | Apple Mac OS X 10.4
All of a sudden my monitor has 'no signal'. I
The wire may be shot. Try purchasing a new connector wire.
Nov 27, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Monitor will be on and working fine and then screen will suddenly go black. says no input signal and that a cable has been unplugged. normally have to turn the monitor off and reboot computer to get...
oh no i have same monitor well the only thing i know to do is take it apart and wiggle stuff maybe a culprit will show up if noting then i would just replace on mine the power plug on the back came loose now i cant take out the plug else itll be useless
Nov 03, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
The screen on my Gateway monitor suddenly went light blue. Has anyone else had this problem or know the solution to get it back to white?
Does the screen remain the same color when you turn it off and back on, unplug it and back in, or disconnect it from the pc and reconnect it?
Jun 15, 2009 | Gateway FPD1975W 19" LCD Monitor
E machine computer monitor problems
your system has a monitor problem try reinstalling the monitor driver through the monitor website
Mar 27, 2009 | eMachines C6535 PC Desktop
Sounds like a Video Card or VGA Cable issue. What kind of Monitor? LCD or CRT?
Dec 18, 2008 | Acer Computers & Internet
17 inch flat screen monitor has trouble turning on
Make sure that the PC video output is set at 60 Hz. The LCD often will accept up to 75Hz but will not work correctly.
May 04, 2008 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Acer 22" X223w LCD Monitor Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
