Question about Gigabyte GA-K8VT800 Motherboard
Post problem hi..i have a gigabyte ga-k8vt800m... i have been told that my problem posting is in the bios. they tell me i lost the bios program and it needs to be flashed.. i have no idea how to flash the bios.. they have said i need a dos boot disk and the bios file to flash the chip which is soldered on the board.. can any one help with the making a dos boot disk ? i can get the bios file from the gigabyte web site.. thanks...
  • Sandy Ruiz Dec 21, 2008
    hi..what media will i use ?i have no post i stated, there is no
    video.. please explain if you can.... thanks
  • 1,179 Answers
You could try a program like EZ-Flash to flash the bios without using a dos disk. Gigabyte should have some type of program on their website that would do the flashing without makeing a disk as most new computers do not have a floppy drive nor does Windows XP/Vista use dos. Hope this helps.
Posted on Dec 21, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 21, 2008
    If you have access to another computer you could download the files onto a CD or DVD depending on what you have on your computer. Then try booting up with the CD/DVD in the drive. If this does not help then you can contact Gigayte and see if they could send you a bootable disc, probably a fee involved, but they should be able to send one. If you do have a floppy drive on your computer then take a 3.5 disk and download the bios flash using a 2nd computer. Save the files to the disk and then reboot your computer using that disk. Follow the onscreen directions and it will talk you through flashing bios. Once you have flashed bios remove disk and reboot. Hopefully this will fix your problem.
GA-G31M-ES2L bios problem
Use CPU-Z from, Luke.
Will tell you what BIOS program, version, and date, you have now,
Click on the Mainboard (Motherboard) tab for info on BIOS.
Need guidance in downloading, and installing CPU-Z post back in a Comment.
Jul 30, 2012 | Gigabyte GA-G31M-ES2L Motherboard
When i reset by desktop bios is not loaded (i think) black screen and not disk activity. Ga-k8vt800m. this happened after cpu frequency change.
If you can still go into the BIOS screen, disable the change you made and see if the system returns to normal.
If not, and you do not remember the settings, go for the default...
Ground yourself to the chassis to dissipate static electricity, with the system off, remove the bios battery.
This will undo any changes you made.
It will also undo and system changes that make you system unique.
At least it should start working again. You can go from there.
Good luck, and don't forget to vote
Sep 27, 2010 | Gigabyte GA-K8VT800 Motherboard
Audio does not work.
Can you look into the BIOS it moght be disable. To get in the BIOS, you normally press Del at POST.
Secondly, check for latest driver or update if necessary.
Feb 25, 2010 | Gigabyte GA-8I945GMF Motherboard
GA-8SIML will not post or boot. Removed all PCI
Firstly you check your RAM by use another RAM and then check it is working or not, after that if display is not coming then check your processor it is fitted properly or not if it have fitted and display is not coming then *********** board's winbond chip have been damaged.
Repair it from a techinician.
Feb 04, 2010 | Gigabyte GA-8SIML Motherboard
Gigabyte GA-8I915ME Beep codes
Hi David,
Do you have your manual for the motherboard?
If no? You can down load it from Gigabyte.
Click on this link:
Go to page 76 for the bios beep code description. Your bios is AMI. Click the next link for AMI beep code error descriptions:
There are two possible troubles. 1) the first bank of memory has a problem. You can download a program that can test your memory without going into windows. Program is free & allows you to create either a bootable floppy disk or a bootable CD-ROM disk. Click here: Scroll down the site until you see, Memtest86+ V2.11. (V2.10)
If your manual is 100% correct than the error is fatal. AKA not repairable but I would suggest you try the above first before tossing the board.
Best of luck David!
Having trouble, post here.
Apr 02, 2009 | Gigabyte GA-8I915ME-G Motherboard
Won't boot
Under normal circumstances you do not need to boot into a drive to flash your BIOS. Normally you would take a dos boot floppy and the latest BIOS firmware and put them on a floppy, which is then inserted into the floppy drive before turning the computer on, and if the bios boot priority is set to boot from floppy before the harddrive, it will ask to boot from the floppy, which allows you to flash the bios from a command line or text graphical interface.
*Note that you may be able to use a cd, but floppy is the oldschool way - if you could boot into an operating system you could use the modern methods which flash the bios while running an OS.
Your board comes with Q-Flash in the BIOS, which means you are able to log into the bios and flash it using this utility and by putting the BIOS firmware on a floppy and inserting it into the computer.
Please see Here for instructions and Here for the latest firmware.
If you cannot access the BIOS, meaning the BIOS is completely bricked, then you will need to buy a new motherboard. Unfortunately there is no way to fix a BIOS which is completely bricked.
Dec 16, 2008 | Gigabyte GA-K8VT800 Motherboard
Ga-k8vt800m motherboard specs..
First, remove all power from motherboard, including the Power Supply ATX plug. Then remove ram and all PCI and PCI-E / AGP (Video) cards even network cards... Let it sit for about 5 minutes and then plug in the necessities: RAM, Video Cards and if nothing works repeat the process but alternating ram slots and ram.
Dec 10, 2008 | Gigabyte GA-K8VT800 Motherboard
No post start up
Only try to remove the cmos battery and reinsert again.......
Cannot change cmos settings.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
Jul 27, 2008 | Intel Gigabyte GA-8IDX 845 AGPset P4...
Gigabyte GA-K8VT800 Motherboard Logo
189 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
