most of these car the plug is simply a plug for convieince you dont need it to hard wire it you simply match up the colors most of them will be the same and then if there are any left over you should be able to do process of elimination hope this helps
Hello tiffinkie: My name is Roger an I will help you. First open the passenger door and locate the fuse panel located in the end of the dash cover. Remove the cover turn the key on. Do not start the motor. Push the reset button located at the top of the instrument fuse panel.The CHANGE OIL light will start to flash.Press and hold the RESET button again. The reset is complete when you hear the chimes sound and the CHANGE OIL light goes out. Should you need further help please just ask. Please rate your answer. This way I know it was helpful. Thank You for using Fix Ya. Roger
ETS stands for Enhanced Traction System.
This is GM's version of Traction Control - it improves traction (to reduce likely hood of skidding) on slippery or loose surfaces.
