Question about Lexmark Office Equipment & Supplies
I have a Lexmark X5150 printer. I have been experiencing what appears to be four lines at the top and bottom of the page when I print something out. The ink is real light in those areas. What can I do to fix the problem?
  • Lexmark Master
  • 5,568 Answers
If you haven't tried the cleaning routine in your Lexmark software, it's worth a shot; it might help.  There are two levels, the toughest one uses a good bit of ink to run.
Posted on Dec 18, 2008
My prints are coming out with Horizontal lines on them. What can I do to rectify this problem?
Please try this approach:
  1. On the printer operator panel, press Options repeatedly until Cartridges appears.
  2. Press the right arrow button until Clean appears on the display.
  3. Press Select. A nozzle page prints forcing ink through the nozzles to the clogged nozzles.
  4. Print your document again to verify that the print quality has improved. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
Aug 21, 2011 | Lexmark X5150 All-In-One InkJet Printer
Printer displays hardware error 0502 wont print " HELP "
The 0502 error can have any of four possible causes:
- A faulty black/photo cartridge
- A faulty color photo cartridge
- A dirty encoder strip
- The encoder strip being out of position
.... most of the time, it's the encoder strip that is giving the problem..
goto
http://support.lexmark.com/index?userlocale=EN_US&locale=EN&page=content&segment=SUPPORT&productCode=LEXMARK_X5150&id=HO2707
May 24, 2010 | Lexmark X5150 All-In-One InkJet Printer
Printing blank
If not printing anything go to printer properties and print a test page. If nothing visible replace cartridge. Cartridges known for drying up when not frequently used. Use cotton swab with rubbing alchohol to clean any dried ink from ports and reciever.
Apr 25, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 black ink cartridges won't print
The original Lexmark-branded 81 and 82 cartridges shouldn't cause a problem - regardless of the country of origin. I can't speak to any reman or refills, because quality varies widely. Have you contacted Lexmark's technical support - accessible via www.lexmark.com? There should be a solution for the Lexmark-branded cartridges. If that doesn't work, put one of the "bad" Lexmark cartridges in their recycling bag and include a note about your problem, including your email address.
Mar 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
I bought two new cartridges for my printer but the printer prints funny. there is no color and the black appears faded. my printer is about 2 years old. have any ideals?
Sounds like the jets may be clogged. You may have to run multiple times till they are good. Print a test after each clean and see if that helps.  You can use the operator panel or the Lexmark X5100 Series Solution Center to clean the nozzles. Using the operator panel 1 Load paper in the All-In-One. For help, see page 16. 2 Press Options until Cartridges appears on the display. 3 Press the right arrow until Clean appears on the display. 4 Press Select. A nozzle page prints forcing ink through the nozzles to clean the clogged nozzles. 5 Print your document again to verify your print quality has improved. 6 To further improve print quality, try wiping the print cartridge nozzles and contacts (see page 44), and then print your document again. 7 If print quality has not improved, try cleaning the print cartridge nozzles up to two more times. you can get the owners manual on line at this address:  http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
please rate this and good luck.
Jan 30, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5150
To read the downloadable manuals below you need adobe reader
If you do not have it you can download it here free use the Get Adobe Reader Button.
http://www.adobe.com
page 6 of the users guide below discusses using your software
Manuals link
http://www.lexmark.com/publications/eng/x5150/index.html
Software link
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+X5150
Choose your Operating System and find your software
Drivers should be installed first -- these allow your computer and printer to work together (along with the wiring)
Utilities provide program functionality outlined starting on page 8 or page 21 of your users guide.
Patches fix problems with drivers and/or utilities and should be applied after both are installed.
Dec 22, 2007 | Lexmark X5150 All-In-One InkJet Printer
Printer problems
You might need to download the Vista print driver for your printer.
Dec 15, 2007 | Lexmark X5150 All-In-One InkJet Printer
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
18 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
