Question about Saeco Magic Comfort Plus Espresso Machine
Brewunit blocked message says the above and the selftest option comes up,it makes a noise like its labouring but nothing happens, would really appreciate a response many thanks
  • yen_sparkle Apr 12, 2009
    i hace saeco royal professional and when i make 3 cups of regular coffees,the machine finished 2 perfect cups of regular coffee but suddenly it stopped working halfway for my third cup.. and in the led it shows brew unit blocked message...
    then i opened the service door and i could get the brew unit out and then i put it back in and the machine start to do a selftest, but after a while it states the same "brew unit blocked" message..
    i reopened the service door but this time i couldnt get the brew unit out.. it is jammed and my dregdrawer couldnt be inserted in... it seems like something from the brew unit is get in my dregdrawer way...
    what can i do? please respond a.s.a.p..
    thanks
  • Anonymous Mar 17, 2014
    when i turned on the unit, it displayed SELFTEST. after a few seconds, it displayed BREWUNIT BLOCK. How can I solve this? thank you
    Problem Solver:
  • 7 Answers
I have the same model and what you have to do is trick the machine that the catching tray is installed and open the door and with a screw driver trick it like the door is closed. This will make the gear turn a few times and you will have to keep going little by little until the gear aligns with the brew unit. My brew unit is back in but no luck with the message going away. I am pretty upset.
Posted on Oct 26, 2012
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
It sounds like the brew unit is stuck with the platform tipped forward. This will prevent the dreg drawer from being put in or out. Your problem could be the result of a few things. Some you can fix, some may take more work. You can get the brew unit out by following the steps outlined on a partsguru.com, Brew group removal.
Posted on Apr 19, 2009
I have 1 problem with my machine, but first of all i would like to ask a question. My steam boiler was not working, so it was recently fixed, a triac was broken on the main board, and i found that the
At the main board there are two transistor on a aluminum.The one is small and the other one is bigger. The big one is usually tip33c or bdxxx if that is damaged group turns slowly.
Feb 06, 2015 | Saeco INCANTO DELUXE Espresso Machine
My krups dolce gusto stopped working. The lights turn on but nothing happens, no water comes out. I have tried every suggestion there is but nothing has happened..I'm afraid I'll waste money on...
Hi, Could be a number of things. Is your pump working. Thermoblock maybe blocked or faulty. A thermo sensor on the thermoblock maybe faulty. Brewunit maybe jammed. Descale will not help if it wont pump. Id be looking at the thermoblock or sensor. If their at fault then the machine will do nothing. See how you go and ill keep a look out for any more questions you may have. Dazza Repairer
Oct 23, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
No matter what I do the Gaggia Titanium espresso machine reads brewunit missing;. This is what I did: I removed the brewunit of the machine to clean it, and reset the N to the correct position on the front...
HI
If the brew unit is in the wrong position when inserted you can knock the lever off the microswitch in the back. If the lever is knocked off you will never get the brw unit miss message to go away. You will have to take the machine apart and replace the lever on the microswitch. Sorry
We made a modification to the brew unit that would prevent this from happening. We modified all the brew units on the compact machines before sending them out so we would never get them back for this reason.
Apr 26, 2011 | Gaggia Titanium Espresso Machine
Hi i have lost pressure on the steam spout i changed the 3 rubber seals but still no better also water comes out of the steamer
Hello, my brewunit make a rackett when I turn it on ... then stops and says 'brewunit blocked ... anyone got any ideas ...
Aug 27, 2010 | Miele CVA615 Espresso Machine
My brewunit is blocked
Coffee fines and mineral scale build up in the brew unit filters and also in the creme valve. The pressure to pump water through the unit fails and the flowmeter tells the electronics that no water has flowed, it in turn stops all processes and displays "brew unit blocked" message. If you're handy, call Miele tech support. The'll walk you through how to remove the drainage cup screw off the left rear of the brew unit, get the brew unit out and return the gearing to home position. It's a 50/50 chance the gears will return or you will need a service tech to pull your coffee unit out and re-sync the gears to the electronics. That's of course if they didn't break.
This blockage is is prevented only by using the cleaning tablets and descaling tablets. Both need to be used as outlined in the instruction manual.
Oct 02, 2009 | Miele CVA615 Espresso Machine
Gaggia Titanium, "Brewunit Blocked"
Check the shower screen in the unit it is possible that it is blocked with coffee oils.
Aug 03, 2009 | Saeco Incanto Classic Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Try to start car and nothing happens. replaced
Do the dash lights come on ? They should come on when the key is turned to the on position. If nothing happens check the engine relay. It is not too expensive to replace if you really want to eliminate that as the problem. Check all wires going to the starter and make sure it is wired correctly.
Feb 28, 2009 | 2001 Pontiac Aztek
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
Brewunit block
kristijordan,
I had this error message on my machine and was able to take care of it by lubricating the brew unit with silicone. I small tube of silicone grease should have come with your machine. If not I found silicone grease at Aco Hardware (not in a tube) and applied it using a toothpick. Machine has been working great since.
Winesnob
Sep 10, 2007 | Miele CVA615 Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
714 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
