Question about Sanyo DP26746 26 in. LCD Television
Listening to t.v. with headset.
I see the plug in for mini audio - i plug in regular head set and nothing comes through headset -- sound continues to come from t.v.
I have not solved it yet , but i do not want to pay a team of experts to to tell me if Sanyo has a headset audio jack.
thanks .
Posted on Dec 18, 2008
Add Phillips headset to HP laptop with Windows 10
how to plug it in? (add?) how to make it work,? and use it?
what head set.? the Phillips model.
USB, or the 2 mini plug type, (2 plugs , 1=head phones, 1= mike)
What is the Phillips part number there.
head sets come in 3 class types.
1: wired. 2,miniplugs
2: USB ( has built in sound chips)
3: bluetooth or with USB to add blue tooth.
what PC? windows 10 sure, but what PC?
Apr 16, 2017 | HP Computers & Internet
When mic n headset is plugged into my motorola cp100 sound comes thru both radio speaker and headset. How do I fix this so that when the headset is plugged in. Sound only comes in thru the headset??
Sometimes on Motorola radios, the vox option get left on. Due to both vox and regular PTT option at the same time, may cause them to RX out of both speakers. So try turning off your vox option which should under menu on the keypad
Nov 09, 2015 | Motorola Radio Communications
Hello, When I connect my headset on my laptop Asus a7sv I get sound but no sound from the speakers. I have Windows Vista en I downloaded the original driver from the asus website. I tried everything....
Most headphone jacks operate as you describe. There is a switch built into the jack that diverts the audio from the speakers to the headphones for "private listening". If it didn't work this way, there would be no way that you could enjoy an audio track or other program with others having to hearing it, too.
You could get around this problem by using an external speaker set and a "splitter cable".
A splitter cable is simply a three ended cable like the one pictured above. The first end has a male plug that matches the jack on your computer - likely a stereo mini plug. The other two ends are usually the same; but the female version. You would plug the splitter into the SPEAKER jack and the laptop speakers would be silenced. Next, you would plug the the external speakers into one of the splitter jacks and then your headset would plug into the remaining splitter jack. You would connect the microphone plug into the MIC jack on the laptop.
You'll have to tinker with the sound levels as there will be feedback issues - depending on how close and loud the speakers are to the headset microphone.
Please rate this reply - and good luck!
Aug 09, 2010 | Computers & Internet
Audio not working i can access only my head set .i can hear song only through head set only when i plug out my audio device speaker notworking.no problem for hardware.before i can hear song through only pc...
Double-click the "sound" icon (bottom-right, beside the Windows "clock") to open the "mixer" application.
Be sure that you have not "muted" your external speakers (not the internal PC speaker).
Sep 10, 2009 | Compaq Computers & Internet
No sound from LX-3000
You will need to change your default audio output device to be the USB headset. You can do this under Sounds and Audio Devices in the control panel. Change it from your regular sound card to the USB headphones. They should be on a drop down list.
Hope this helps
Jul 14, 2009 | Microsoft LifeChatâ„¢ LX-3000 Headset
Simultaneous audio through headset and regular speakers?
This is not possible with Windows. You would need to purchase a mixer program of some sort. The USB headset is seen by the Operating System as a stand alone sound card. Windows will not mix two sound cards.
Mar 07, 2009 | Logitech ClearChat Pro USB Headset
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Jan 04, 2007 | Plantronics DSP-500 Headset
Sanyo DP26746 26 in. LCD Television Logo
180 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
