Question about Panasonic Lands Phones
I have a set of three panasonic cordless phones. Purchased this year. PQKK10604. Today all three phones do not allow dial tones and will not allow calls in or out. There is a green figure in the far right of the screen that looks like a battery. The question is would all three phones have the batteries go at the same time? What else might the issue be? I have 2 other phones in the house and have dial tones and can call out on these lines.
sandiiii
  • 17 Answers
SOURCE: phone repair
the links tat r there inside the phone are shorted as they r very thin threads like..just go to a repairer and he will resoulder the links and the problem will be solved..for temporary work just open the phone and remove all dust ..mostly keypad will start working
Posted on Nov 24, 2007
SOURCE: dial tone
throw it against the ******* wall..I hate these god damn phones
Posted on Apr 01, 2008
  • 12 Answers
SOURCE: i have no dial tone on one line. call my number and it rings
IT IS DUE TO NETWORK FAILURE OF THAT LINE
Posted on Jan 05, 2009
SOURCE: panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
Posted on Apr 18, 2009
feelfemi009
  • 277 Answers
SOURCE: cordless keep searching - no dial tone - nothing...
just check the settings and apply dialling tone
Posted on Jul 10, 2009
No dial tone on my Panasonic cordless
other hand sets not hung up properly , switched off after a call
no outside service line ---call the service provider
Aug 22, 2016 | Panasonic KX TG1031 Cordless Phone
How do I intergrate a KX-TD 7896 into existing phone system?
Take one of the existing extensions on the system and listen with a normal telephone if you get Dial tone...Then if you do Plug in your Cordless phone and listen if you do get it then... If not..most probably the cordless is faulty.
May 27, 2014 | Panasonic KX-TD7896 Cordless Phone
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
Problems with handsets
Are they cordless phones?If they are they get there dial tone from the base.If there is a blinking red light on the hand sets they lost communication with the base.Check your user manual to see if you need to program them to the base.
tk46
Jun 09, 2008 | Panasonic KX-TG1033S Cordless Phone
Dial tone
Mar 25, 2008 | Uniden Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
46 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
